Attaching bush hog to Kubota L3830
   / Attaching bush hog to Kubota L3830 #1
lhgrant
Dallas, GA
Kubota L3830 HS
Hi,
I'm getting ready to hook up the bush hog for the first time. Any particular order I should start attaching, to make it the easiest?
Liliane
   / Attaching bush hog to Kubota L3830 #2
Whatever works best for you, but I always hook up the two lower links first. If things are not lined up straight, can actually hook up one and very carefully and slowly drive the tractor forward or backward a tiny bit to line up the other one, then can use the 3-point hitch to raise the front end of the brush hog if necessary to hook up the top link. Then shut down the engine and hook up the PTO driveshaft.
   / Attaching bush hog to Kubota L3830 #3
The way I do it is lower links first, PTO shaft second and then the top link.
Thanks, guys, I'll go try it.
Liliane /forums/images/graemlins/wink.gif
2007 Ford Ranger Pickup Truck (A50323)
2007 Ford Ranger...
WESSEX RMX500 LOT NUMBER 45 (A53084)
WESSEX RMX500 LOT...
2017 John Deere HPX615E Gator Utility Cart (A51691)
2017 John Deere...
New Wolverine Skid Steer Hydraulic Breaker (A53002)
New Wolverine Skid...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
NEW Fork Extensions (A53002)
NEW Fork...
