I'm almost ashamed to ask this but what is the procedure of connecting a 3 point hitch backhoe to ones tractor?
I just purchased one and want to connect it to my 2430 Jinma.
Though at first glance it appears straight forward but the more I look the more questions I have and the instructions are not all that great (attached are some pics of the back side of the hoe sitting in my trailer).
The mounting hardware is straightforward, two bolt-on positions at the bottom and one on top.
This gives me the horizontal member that I believe connects to the "top llink" position of my tractor.
According to the instructions the bottom arms of my 3pt then connect down below to the same position as the support diagnal members of the mounting hardware.
I guess the real question I have is how do you set up the bottom arms so they will carry some load as I don't think the top link should be carrying all the load.
Obviously the bottom arms are hydraulically adjustable and could be put into any position so what is there to prevent them from moving? And how do you know when you have it correct?
Is there a way of locking the arms?
/forums/images/graemlins/confused.gif
Thanks for any help as can be seen I'm still quite the novice,
HankC
HankC
