attaching 8N ford PTO
   / attaching 8N ford PTO #1
hookerbob
Fruitvale, TX
1952 *N Ford/1947 2N Ford
When attaching the impliment power shaft (Mower, etc)to the pto, there seems to be a pin that moves in and out, can you explain the operation of this ? Also is there a small entrance hole on the pto shaft that must be alligned ?
Thanks, have just got a mower for mine and trying to attach it.
Bob
   / attaching 8N ford PTO #2
The pin locks the PTO shaft of the implement to the PTO output shaft of the tractor so the shaft doesn't come off when you are using the implement. If you look into the end of the input shaft and push the pin, you can see that it is not round all the way. There is a chunk missing when you push it in. On the PTO output shaft of the tractor, you should see a groove half way up the shaft and all the way around. The pin aligns in that groove when it is in the out position to lock the shaft to the tractor. Push the pin in, put the shaft onto the tractor as far as it will go, release the pin, pull the shaft back and the pin should pop back when it hits that groove. That's how you know the implement is properly attached.
As far as the hole in the shaft, I'm not totally sure what it is for. I suspect it allows attachment of a pulley to run a stationary piece of equipment using a belt (buzzsaw) from years gone by. I have seen equipment where the pin was missing and a bolt was put through the PTO and implement to attach it. I don't recommend it.
   / attaching 8N ford PTO #3
the hole is for a pin on yoke vs a QD type yoke...
Thank you, thank you,
Works like a charm
Promtly run out of gas
48" Pallet Forks  (A52384)
48" Pallet Forks...
BY VALLEY INDUSTRIES 60 R22 823 LOT NUMBER 236 (A53084)
BY VALLEY...
2003 Pace American Trailer, VIN # 4FPW540373G068816 (A51572)
2003 Pace American...
1994 East Manufacturing Trailer, VIN # 1E1U1Y288RRC16516 (A51572)
1994 East...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
