At what point does a tractor become a tractor?
   / At what point does a tractor become a tractor? #1
johndeere2210
Nebraska
John Deere 2210
Just sitting here tonight reading some old posts and I noticed that there are many times that MTD, Yardman, Craftsman, and etc. are mentioned as being tractors. I guess that raised a question in my mind as to what constitutes a tractor. Is it the size of the property that is being maintained, or is it strictly related to the machine itself? Is it the way a machine is equipped (i.e. TPH, PTO, hydraulics)? Is it the engine horse power? Maybe it is the position of the crankshaft (vertical or horizontal). I would like to state that I do not have anything against MTD, Yardman or Craftsman (I just love machines with engines). I am just curious to know what you all think constitutes a tractor. /forums/images/graemlins/smile.gif
   / At what point does a tractor become a tractor? #2
I am not by any means an expert, but I would classify a tractor as having multiple attachments and uses. I do not classify riding lawn mowers which are only mowers as tractors, but if it could run other attachments it could be a tractor. Look at some of the old tractors ie an Alllis Chalmers G or a John Deere H. Each of these machines was only about 10 hp but were truly tractors. IMHO the multiple uses makes a tractor, but then again what do I know?
   / At what point does a tractor become a tractor? #3
I agree with Jim. I just traded a JD 214 garden tractor for a JD 2210. I considered my 214 a tractor. I plowed my garden with it, I blowed snow with it and I pushed dirt with it. 99% of the time I mowed grass with it. I always considered it a tractor.
   / At what point does a tractor become a tractor? #4
I remember reading somewhere here in the TBN Halls of Wisdom that when you shift your weight to one side in an effort to gain stability or traction, and it has no effect, then you're on a real tractor /forums/images/graemlins/wink.gif
   / At what point does a tractor become a tractor? #5
When you can use it without fear of breaking it...then you're on a real tractor.
   / At what point does a tractor become a tractor? #6
"When you can use it without fear of breaking it...then you're on a real tractor. "
Drats...I guess I can't consider my 95 hp 4020 J.D. a real tractor then. /forums/images/graemlins/shocked.gif
Suppose I'll have to find something bigger/newer. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Heck, I can break anything. /forums/images/graemlins/crazy.gif
   / At what point does a tractor become a tractor? #7
As soon as the key is turned and there is a satisfying response. Before that it's just a hunk of metal and other assorted stuff.
Egon /forums/images/graemlins/grin.gif
   / At what point does a tractor become a tractor? #8
I think you should further breakdown "tractor". If it has a 3PT hitch on it, it's a utility tractor. If it doesn't, it's a lawn tractor. Many lawn tractors have more hp than utility tractors.
You might even want to say, if the dealer asks you what type of tires you want on it, then it's a tractor. As far as I know lawn tractors just have what they come with, which is a turf tire.
   / At what point does a tractor become a tractor? #9
If it's <font color="green"> green </font> of course. /forums/images/graemlins/wink.gif
Just kidding.
   / At what point does a tractor become a tractor? #10
"If it has a 3PT hitch on it, it's a utility tractor. If it doesn't, it's a lawn tractor."
Then I guess that 300 h.p. 4 wheel drive articulated Stieger must have been just a lawn tractor...glad I didn't buy it. /forums/images/graemlins/grin.gif
I've seen LOTS of ag tractors without a 3PH. Maybe that one should be re-worded to just: "If it has a 3PH it's a tractor."
Of course that would make my Dad's 316 J.D. a tractor too /forums/images/graemlins/tongue.gif
Ah well...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
Kubota BV4160 (A50123)
72" Hydraulic Broom  (A52384)
72" Hydraulic...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
