AT-720 FEL for Ford 1700
   / AT-720 FEL for Ford 1700 #1
wonl2
Taylors
Ford 1700
I have a Ag-Tech AT-720 FEL for 1982 Ford 1700 and I'm trying to rebuild the lift and bucket hydraulic cylinders. I took the cylinders to a local hydraulic shop and they noticed that one of the bucket cylinders was slightly bent. The hydraulic shop tried straightening the bent shaft but couldn't. lift and bucket cylinders are 1 1/2" diameter. Lift cylinders have 1 1/4" shafts and the bucket shaft is 1". Lift travel is 24" and bucket travel is 16" The connection pins are 5/8". The cylinders are original (35 years old) and some rusty areas.
Here are my questions for the forum members:
1: Is it worth replacing the bent shaft considering the fair/good condition of the cylinders?
2: I see some double action cylinders for sale that are around $130 each. Rated for 3500psi.
3: Original pin holes are 5/8", can I drill out these holes to fit the larger pins?
4: Do they make sleeves/spacers that can be used with my original pins?
5: Any brands of cylinders to stay away from?
Thanks for your responses. Any suggestions and/or options are greatly appreciated.
Thanks!!
Phil
2018 INTERNATIONAL LT625 SLEEPER TRUCK (INOPERABLE) (A52472)
2018 INTERNATIONAL...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
2004 Ranger 195 VX Comanchee Bass Boat with Trailer (A51573)
2004 Ranger 195 VX...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
