ASV woes...
   / ASV woes... #1
floridaforestry
RC-100
I am looking to see if anyone has any ideas they can pass along. I have a RC-100 with the Perkins engine in it that won't start. I get all the lights, a/c to come on when the key is turned, just no fire to the motor. No turn over or click, nothing. Machine has had is issues but this on has me stumped. Any help would be greatly appreciated.
   / ASV woes... #2
It sounds to me like some safety thing is keeping it from starting.... like a PTO engaged on a tractor. Are all the levers, settings, etc in the start position? Sometimes the simplest things are the hardest.
   / ASV woes... #3
The QD switch (upper left) and the high & low flow switches (upper right) will prevent the engine from starting. Those switches can be a problem if rainwater gets in around the front light gaskets in the overhead console.
   / ASV woes...
The QD switch was in the "unlock" position. Had no attachment on it at the time. The simplest things are the most aggervating.
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
2016 Takeuchi TL8 (A47384)
2016 Takeuchi TL8...
2012 Ford F-150 Pickup Truck (A50323)
2012 Ford F-150...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52128)
2003 International...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
