asv slide up door/window in sr-80 pt-80
   / asv slide up door/window in sr-80 pt-80 #1
millpond
NH TC 55 DA
Jmfox: I forgot to ask you how your sr-80 performed in snowy conditions. I thought the window seal wasn't that tight and thought you or somebody could shed some light on both the winter wind with slide up door design and also how did the windshield wiper perform in snow conditions. Will the wiper handle blowing snow from snowblower attachment ? :confused: All comments on this door issue is much appreciated.
   / asv slide up door/window in sr-80 pt-80 #2
The seal on the SR80 keeps the cab clear and warm in single digit weather. The heater is actually a little too much for me, so don't use it and when I do I keep the window open. I rarely used the wiper because the heat in the cab keeps the inside and outside clear and dry, and it's a good thing as the wiper is not that impressive.
jmf
Thank you I suspected that the wiper blade wasn't going to help much with blowing snow. Maybe just going to use a blade and bucket or widow open if
it isn't too cold. Thanks again.
Jmfox am I crazy to spend the money on ASV pt 80 if the primary application
is winter time snow removal..? In all your planning and research before purchasing SR 80 where did you weigh winter time use vs other seasonal tasks you envisioned. I know the ASV is the best track loader in the market, but is really meant for dirt work and spring/summer/fall hours vs blowing snow
over 4 months.:confused:
   / asv slide up door/window in sr-80 pt-80 #5
I did not intend to use my machine for snow removal. I was surprised on how well the SR80 handled the winter chores, but did not attempt any commerical snow plowing commitments. Do your jobs require transporting the machine? This is also a problem with track machines. The best use for these machines is a year around plan on a variety of surfaces. What are your other options? Unless you are in the southern hemisphere, I assume you are looking to purchase next winter?
jmf
The machine doesn't need to be moved that much. It will be located in Northern Vt. I have a gravel driveway which is 3/4 of mile long and I know that after a few good storms the snow banks will start to creep in.(plenty of wind and drifting snow as well) Instead of backing up with rear PTO machine and CUT I think the best multi year plan for keeping up with the road is a solid front mounted hydro blower. Now over the next few years there is still plenty of timber to be cleared and either sent to the mill or set up for fire wood. The property can be very wet as many natural springs run through the land. Running the CUT and Fransgard winch in some sections is super but I need to get through wetter areas as well. Back filling on various buildings and plenty of landscape work over then next 3/4 years. Also wife wants horses and I love the zero turn track set up to move through barn. What has been weighing on my mind is really the Toolcat for the best winter time applications, but I still need a track machine for woods ground clearance(ASV the best) and lifting. Will ASV be fine in a lot of cold winter work..?
   / asv slide up door/window in sr-80 pt-80 #7
The ASV will handle the chores you describe with time to spare. I normally plowed 3 driveways with a Polaris Ranger UTV, but had to be careful about where I pushed it during big snow. With the ASV I dared it to snow. I could put and pile snow wherever I wanted. Snow blowers make a nice clean cut but they are a little slow and problematic on gravel. I was thinking about an adjustable pusher for the future. I did consider the Toolcat, and still like it, but I was concerned about ground pressure, traction, thorns and hydraulic muscle. (For plowing snow on pavement, the TC seems to be a winner.) The SR80 should earn its keep in landscaping environments and all chores on soft surfaces. In the winter, the rubber tracks get enough ice lubrication to travel on pavement, but dry pavement is not a good idea for track machines.
jmf
Then the last conundun would be this. Rather than buy a blower to start I should be investing in a blade, but should that blade actually be heavy duty dozer type (quick-attach has 1300lbs 6 way with wheel set up) that I can grade with and use as a snow :confused: plow with skid shoes adjusted and wheels taking out the usual waves from fixed bucket..?
   / asv slide up door/window in sr-80 pt-80 #9
I basically used my ASV 4-in-1 bucket, but it is generally not a good idea to mix dirt and snow. Most dirt attachments are designed to dig and snow attachments are designed to push. In my case, the 4-in-1 dug up the grass as easily as the snow. If I had a snow blade it would have been lighter with no cutting leverage. Considering the season, you should concentrate on your dirt applications. As a dedicated blade, from what I hear, 6 way blades are far better than the blade option on the 4-in-1, but they are not designed for snow. Six way blades are heavy and designed to cut. If you're an accomplished operator you can get pretty fancy with whatever is hooked on the front, but life is easier if you use the right tool rather than the same tool for the job(s). I think I would rather rig up an old snow plow blade rather that use a 6 way dirt blade in the snow. Is there anyone here with experience plowing snow with a dirt blade?
jmf
Jmfox: I did spend a little time reviewing other "snow removal systems" the conflict between blowing, plowing, use the rear blade, and I thought I would
bring another question on to the table. Hiniker makes a reverse c blade and v blade in that context how would you stack those up vs a straight pusher/regular blade. Lastly I'm not sure I understand float capabilities with ASV/skid steer machines. Can you get the arms to free float while plowing so that as you move through different elevations the blade will stay down on the surface, or do you need to adj with your pilot stick as you go..:confused:
2024 VALLEY PIONEER C08 MINI DUMPER (A45046)
2024 VALLEY...
2024 VALLEY PIONEER STAND ON MINI COMPACT TRACK LOADER (A45046)
2024 VALLEY...
USA 36" 9.5T Excavator Bucket (A42203)
USA 36" 9.5T...
25 Ton Lowboy Trailer (A44391)
25 Ton Lowboy...
2013 FORD E350 BOX TRUCK (A43004)
2013 FORD E350 BOX...
(2) FORD TRAILER HITCHES (A45046)
(2) FORD TRAILER...
