ASV Skid Steer on incline
   / ASV Skid Steer on incline #1
ryanengen
I have a 2007 ASV RC-60 skid steer. When I am on an incline at about a 40 degree angle or more it freezes up. It will not go forward or backward and the bucket stops working as well. cant find any safety switch. Checked the hydraulic fluid and it is full. The engine keeps running perfect but the machine will not move. I had to pull it out of a swamp with a tele-handler today. Any ideas before i run it down to the dealer? Low hydraulic pressure? Thanks
   / ASV Skid Steer on incline #2
Possibly the hydraulic oil intake is uncovered or the head f oil is too low to feed the pump. I would also be concerned about the engine on that steep slope. Is yours equipped with either the Cat engine or Perkins equivalent? I believe the oil pan limitation is 36 degrees for the deepest available sump, any direction meaning side hill or fore/aft.
It is a perkins engine. I probably exaggerated the slope degree. It probably stops working at more like a 25 degree incline. By head F oil do you mean the engine oil? Also how would I check if the hydraulic intake is uncovered?? It is to the full line on the gauge.
Thanks again for your input!!
   / ASV Skid Steer on incline #4
I mean hydraulic oil above the inlet. If the machine tilts enough so that a tiny bit of the outlet from the hydraulic tank (where it feeds oil to the hydraulic pumps) is uncovered, the pump(s) will suck air and you stop. I am not exactly sure on your ASV but I believe it's hydrostatic pumps are fed by either a gear (external) or gerotor (internal) pump. Those pumps supply both control oil for the propel pumps and charge oil. In the case you describe control oil pressure is lost allowing the propel pumps to destrokes to neutral and you come to a stop. Towing it to a flatter slope gets oil back where it belongs, the pumps stroke and you are on your way. Machines I've been involved with - we make sure the oil inlet is always covered beyond the steepest slope we expect a person to be operating because oil sloshes around. I feel certain that ASV would be the same. The symptoms sure point to this being the problem though because it worked again once you got it to flatter ground. If it was something like an air leak in the inlet hose(s) the problem should have stayed.
Perkins has been a Caterpillar company since the mid 90's. The engines are the same except for the tags and the color, at least in the size used in the ASV. The engine division applications engineer would visit our facility in Minneapolis, then go on to the ASV plant in Grand Rapids, MN. Then Cat sold its share of ASV to Terex and I haven't kept up on them since. That's why I remember the max slope for the engine with deep oil pan - something customers frequently ask.
   / ASV Skid Steer on incline #5
I would bet against operation at 40 degrees and above. It is physically unlikely and would require optimum traction and extreme care to achieve - and the ability to do work would be zero.
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
WHYNTER ARC-102CS PORTABLE AIR CONDITIONER (A51248)
WHYNTER ARC-102CS...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
UNUSED FUTURE FT36CJ STAND ON SKID STEER (A51247)
UNUSED FUTURE...
2014 RAM 5500 Bucket Truck - 4X4 - Cummins Diesel - Automatic Transmission -Versalift SST40 Boom (A53472)
2014 RAM 5500...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
