ASV RC100 problem stuck in high speed
   / ASV RC100 problem stuck in high speed #1
Mastiffaruba
Aruba
ASV RC100
Hi there, I have a ASV Rc100, that is stuck in hi speed, I'm running out of things to check and replace. so far I have done the following.
Replaced both Drive motors, checked hi/low speed solenoid & shaft, replaced all hydraulic filters, replaced all seals in hand controller. checked all electrical wires for any signs of open wires, check all fuses, and connection in fuse box.
I managed to get it running in low speed for about 5 minutes, went over a bump and i'm stuck in high speed again. I'm leaning towards bad electrical connection somewhere and I have been searching for a wiring diagram but no luck so far.
Any suggestions would be welcome before I set a match to it.:fiery:
UNUSED Steel Diamond Plate (A50860)
UNUSED Steel...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
PLEASE VIEW ALL PICTURES!! (A50774)
PLEASE VIEW ALL...
2015 Ford F-150 4WD (A51039)
2015 Ford F-150...
2013 VOLVO VNL860 TANDEM AXLE SLEEPER (A51219)
2013 VOLVO VNL860...
2020 Case IH 8250 4WD Combine (A50657)
2020 Case IH 8250...
