ASV RC 60 Hydralics leak down
   / ASV RC 60 Hydralics leak down #1
chassb123
oxford
asv rc 60
Hey Guys! Im new and having issue with my asv rc 60. It runs and operates fine with the exception of the lift the bucket leaks down even with the machine running. So while hauling dirt or empty i have to pay attention to keep the bucket raised. Was wondering where to look. Is it the loader valve leaking down? It leaks fast enough you can see it going down about a 4-6 inches per minute. Thanks
   / ASV RC 60 Hydralics leak down #2
Probably worn cyl seals.
Well I thought that at first but the tilt on bucket does the same. Possible 4 cylinders are bad?
   / ASV RC 60 Hydralics leak down #4
Does your ASV RC60 have safety devices built in to prevent movement if you don't have the safety bar latched or is this machine old enough not to have these safety features?
If it have these safety features raise the bucket a few feet in the air and activate the safety latch. Does the bucket still drift down?
Does it fall all the way to the ground? If yes then i would suspect that your control valve is leaking. If it drops part way and stops then I would suspect cylinder seals are leaking.
   / ASV RC 60 Hydralics leak down #5
You can remove the hoses from the lift and tilt cyl, and tie the hoses up vertical, and start the engine.
If your valves are in neutral and leaking, you will see fluid coming out of the hoses.
Thanks for replying. It doesn't have the safety features you talked about. It does leak all the way down and even bucket tilts back flat when it comes to rest.
J.J. thats a good idea. I will try that. Thanks
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
2014 Ford Escape (A50323)
2014 Ford Escape...
John Deere 2440 Tractor (A52384)
John Deere 2440...
(APPROX 20) 2" X 3" X 49" THICK TUBING (A51247)
(APPROX 20) 2" X...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
