ASV RC-100 Power Quick attach failure
/ ASV RC-100 Power Quick attach failure #1
loghog01
I have a 2005 ASV RC-100. The machine set idle for about a week and when I went to use it again, the power quick attach will not work. Any ideas on what the problem is?
/ ASV RC-100 Power Quick attach failure #2
Thats what I have is '05 ASV, but I've had no problems with that. It might be hole in hyd. line, no hyd fluid, bad switch, etc... How many hrs you have, did you buy it new?
My '05 ASV has approximately 1800 hours(the hour meter was not working when I bought it used a few months ago). I'm still trying to pinpoint the problem with the quick attach not working. I'm sure it is an electrical problem...there are no noticable hydraulic problems.
How do you like your Magnum mulcher? I run an old Marvel tree cutter(heavy duty brush hog) mounted on a hydraulic PTO adapter made by HH Fabrication. It works great in trees and brush that are less than 6 inches at ground level.
/ ASV RC-100 Power Quick attach failure #5
I like my magnum mulcher, but I would buy differently if I were to do it over again. Like any machine it will break & you fix & keep going!!!!
UNUSED JCT 84" HYD DOZER BLADE (A62131)
UNUSED JCT 84" HYD...
New/Unused Wolverine 78in Land Leveler (A61166)
New/Unused...
UNUSED JCT 84" HYD ROCK GRAPPLE BKT (A62131)
2008 Chevrolet Silverado 3500 4x4 Crew Cab Pickup Truck (A61568)
2008 Chevrolet...
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
2018 Ford Escape AWD SUV (A61569)
2018 Ford Escape...
