I understand that the RC-100's that come as part of the Brush Mulching & Forestry Packages have manual & not hydraulic quick-attach mounts on them that the Fecon cutter head mounts to normally with the additon of also being bolted to the quick-attach mount. From what I've told by my local dealer this is to make a much stronger connection between the Fecon head and mounting plate.
Several questions for those of you that might have 1st hand experience with this:
1. How long does it take for example to unbolt the Fecon cutter head and say mount a brush grapple or vice versa? Will it be a major PITA to switch attachments with the manual quick-attach & bolts?
2. Has anyone had trouble with using a Fecon cutter head on a hydraulically operated quick-attach equipped RC-100? Have you seen cracks in the mounting plates or what?
