square1
Veteran Member
I have two "experts" giving conflicting advice on repair of a badly alligatored asphalt parking lot. The original installation was, in both experts opinion, very well (overly) done in regards to the base and surface. This is evidenced by the fact the lot isn't heaving or settling. The surface has merely gotten to the point that repairing a section this year and a different section next year, etc... has become more costly than doing the entire lot. Previous repairs have always been cut out a section down to the dirt and install new asphalt. These repairs have held up well.
One adviser says the best solution will be to grind up all the asphalt (down to the dirt base), remix it and put it back down. The other is recommending milling off 3 inches (the asphalt is 6" thick
) and putting down 3 inches of new asphalt.
It's a parking lot, not a highway, it does see axle loadings in excess of 10,000 pounds on a regular basis.
With cost out of the picture, which would be the better solution?
With cost in the picture, how much more (or less) percentage wise would you pay for the solution you suggest over the other option?
Are there other repair methods that should be considered?
