Ariens GT18 speed varying
   / Ariens GT18 speed varying #1
jnachtrieb
Big Rock, IL
Ariens GT 18
My Ariens GT18 does not keep a constant speed, even on flat ground. Following the service manual procedure, I have tried to adjust the linkages, to no benefit. Any idea where to look or what might be wrong?
   / Ariens GT18 speed varying #2
Is the engine speed varying or is the engine speed constant and the tractor ground speed varies?
How does the speed vary? Increase, decrease, or random up and down?
Engine speed is constant. The speed varies up and down but depends on load--for example a small hill or when the front wheels are turned which causes drag. When the tractor "takes off" at a higher speed it feels like when a car's automatic trans locks in. The drive train also sounds different.
Engine speed is constant. The speed varies up and down but depends on load--for example a small hill or when the front wheels are turned which causes drag. When the tractor "takes off" at a higher speed it feels like when a car's automatic trans locks in. The drive train also sounds different. It reminds me of a slipping clutch in a stick shift.
Engine speed is constant, ground speed varies. Speed decreases under a load (small hill or sharp corner). Feels like a slipping clutch. Ground speed increases on level. Feels like when an automatic trans locks in.
stump grinder for mini skid steer (A53421)
stump grinder for...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
2013 PETERBILT 367 HOT OIL UNIT (A53843)
2013 PETERBILT 367...
91013 (A48082)
91013 (A48082)
