Are these good cylinders to design a loader around?
   / Are these good cylinders to design a loader around? #1
TX
YM186D, Ditch Witch 6510
I'm looking at designing a loader for a machine with 64hp. Don't know the pump capacity, but it should be quite high. It has a number of 12.5gpm valves (8 of them) already on it (if i use 2 of those valves rather than adding a separate loader control). I'd like the loader to be able to handle 1600lb of or so of dirt, and use a 6ft bucket.
Haven't drawn up a full design yet, but i found a good deal on some welded cylinders and i'd like to grab them while they're available, IF they're suitable to "build a loader around".
Here are the specs:
BORE 2'' Bore - 3000 PSI COLUMN LOAD 9420 lbs.
STROKE 16'' PORT SIZE SAE 6
ROD DIA 1 1/4'' PIN DIA 1''
RETRACTED 26 1/4'' SHIP WT. 22
EXTENDED 42 1/4''
Do these sound like a good choice?
I know i really should do a full design before deciding on the cylinders, but i can get these quite cheap and don't want to miss the deal, and am willing to "design around them" if necessary.
Thanks for any advice.
PS, the loader is NOT for my YM186D :)
   / Are these good cylinders to design a loader around? #2
Just off the cuff, they sound a little small for a 64HP machine. Don't put the cart before the horse...there are quite a few places to get a good price on cylinders when your ready for them.
   / Are these good cylinders to design a loader around? #3
I would just look at a loader that would be used with that size tractor. Get some specifications off the data sheet on line if they have one. If not go to a dealer and look at one.
   / Are these good cylinders to design a loader around? #4
Welcome to TBN. Don't know about your cyl. concerns but I see you have a 186D. I have one as well....nice little tractor!:thumbsup:
2009 Gleaner A76 Combine (A50657)
2009 Gleaner A76...
STIHL TS420 CUTQUICK SAW (A50854)
STIHL TS420...
2014 VOLVO VHD DAY CAB (INOPERABLE) (A50854)
2014 VOLVO VHD DAY...
2013 FORD F-450 UTILITY TRUCK (A51222)
2013 FORD F-450...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
2014 INTERNATIONAL PRO STAR (A50854)
2014 INTERNATIONAL...
