Are these correct for TL2100?
   / Are these correct for TL2100? #1
corelokt308win
Ok, does this look right then?
Also, am I forgetting anything?
Filters:
Oil: Napa 1348 (B159 Baldwin) if 3/4 -16 threads
Napa 1344 (WIX 51344) if 20mm threads
Fuel: Napa 3262
Air: Napa 6326
Car Quest 88326
Hydraulic: Cleanable element
(Where do I get a new outer cover or complete assembly?)
Fluids:
Motor oil: Rotella (Summer)
5w30 (Winter)
Hydraulics: Standard Hydraulic Oil
Power Steering: Hydraulic type 55 oil, or Automotive Power Steering Fluid.
(Located under battery, has a drain plug and a filter screen)
Front Axle: 80w90
(Fill until covers axle shaft as seen through fill hole. Drain by removing the wheels and removing drain plugs.
Grease Fittings:
Standard Wheel Bearing Grease
Glow Plugs:
??? Call Rainbow, or possibly an Isuzu Commercial Truck dealer?
   / Are these correct for TL2100? #2
You can use a 15w-40 diesel oil year around.
I'd recommend a hydraulic/transmission fluid = to or better than JD303
91013 (A48082)
91013 (A48082)
PORTABLE INDUCTION HEATER (A52472)
PORTABLE INDUCTION...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
