Are there any benefits to external cylinders on 3 point
   / Are there any benefits to external cylinders on 3 point #1
4tillingdirt
nc
N/A
I know some of the compact tractors like Kioti NX have these, just wondering if there are any benefits other than accessibility for repairs? How often do these cylinders require repair anyway?
   / Are there any benefits to external cylinders on 3 point #2
I think that what you will find, is that for each manufacturer, the tractors that have the external 3pt lift cylinders have a higher lift capacity than those with the internal cylinders in their lineup. I'm pretty sure that is uniform from manufacturer to manufacturer. ;)
   / Are there any benefits to external cylinders on 3 point #3
Also external cylinders makes it very easy to hook up a accumulator and a suspension system for the 3 pt when roading the tractor.
Antonio Carraro offers this option from factory since they use external cylinders. A simple accumulator with a shut off valve.
   / Are there any benefits to external cylinders on 3 point #4
Should something go wrong with internal parts associated with rockshafts, the tractor may have to be split for repair.
Nice not to have body parts around external parts of rockshaft when connecting implements.
Perhaps a slightly more precise control with external hydraulic cylinders relative to rockshafts.
(My rockshaft experience is from operating Deere economy tractors; hydraulic cylinders with Kubota.)
I know some of the compact tractors like Kioti NX have these.
Kubota Grand L = hydraulic cylinders. Kubota MX = rockshafts
   / Are there any benefits to external cylinders on 3 point #5
Should something go wrong with internal parts associated with rockshafts, the tractor must be split for repair.
Every mechanical direction change denigrates lifting power power at the Lower Links.
Kubota Grand Ls = hydraulic cylinders. Kubota MX = rockshafts
Not really. Tractor manufacturers made it so the top housing of the rear transmission case, holds all the rockshaft parts, including cylinder and valving associated with it.
So the tractor doesn't really need to be split. Some tractors even have a cover for the rockshaft cylinder under the seat that allow you to pull the cylinder out without taking anything else apart to change the seals.
   / Are there any benefits to external cylinders on 3 point #6
Most smaller tractors that have an internal cylinder only offer 1 cylinder. External have 2.
   / Are there any benefits to external cylinders on 3 point #7
I suppose that external cylinders would also make it easier to offer a down pressure option on the 3PH. I notice that some ag tractors have plumbed ports at both ends but I'm not sure that makes for down pressure capability. Perhaps its just plumbing the breather back to the reservoir?
   / Are there any benefits to external cylinders on 3 point #8
I think you'll find those with external cylinders still have one inside. Normally the external cylinders are for lift capacity increase, not to replace inside ones.
Check 3pt lift ratings, get a tractor that will lift what you want, external cylinders or not.
   / Are there any benefits to external cylinders on 3 point #9
Toolcat 5610 runs one external double acting cylinder to raise/lower the 3pt. It does not have down pressure because the rockarm pivot design has the cyl only able to raise. It still floats like most other tractor 3pt.
   / Are there any benefits to external cylinders on 3 point #10
I think external might be easeir and cheaper to repair. On the other hand, the seals are exposed to the dirty outside world.
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
2011 New Holland Boomer 90 MFWD Utility Tractor (A52748)
2011 New Holland...
Kubota Tractor Plate Attachment (A50325)
Kubota Tractor...
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
2003 Isuzu NPR-HD Truck, VIN # JALC4B14637000853 (A51572)
2003 Isuzu NPR-HD...
