Are P.F. Engineering FEL plans good?
   / Are P.F. Engineering FEL plans good? #1
GPintheMitten
Elite Member
Flushing, Michigan
Kubota B2620 with BH65 backhoe, Ford 2N
I want to build a FEL for my 1983 Kubota B6200 HST. Are the P.F. Engineering plans good? What would you recommend? Thanks.
   / Are P.F. Engineering FEL plans good? #2
can't comment on PF engineerings' plans but can offer a suggestion - if you've got the patience to wait a bit, you ought to be able to find one prebuilt
i bought one earlier this year that literally was a bolt on affair - for $350 and it came with the tractor it was on (tractor is a basket case) - it needs all new hoses and i'm going to modify the hinge bosses a little but otherwise it saved me a lot of work, time and some serious coin
there have been quite a few show up on egay and a few of the other forums that folks picked up from 350 to 1000 - more have surfaced than i'd thought would, but only noticed after i found mine
if it helps
Thanks Larry. I'll check that out. What other forums?
Thanks for links guys. Anyone built FEL from either CADPlans or P.F. Engineering plans? Other plans?
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
2009 SolarTech Silent Messenger II Solar Message B (A53117)
2009 SolarTech...
BAUER ATD-750 VERTICAL HYDRAULIC PIPE HANDLER (A53843)
BAUER ATD-750...
2020 Chevrolet Express (A50123)
2020 Chevrolet...
Vermeer T-658 Tracked Trencher (A52384)
Vermeer T-658...
