Oil & Fuel Are NH oils/fluids approved for LS?
   / Are NH oils/fluids approved for LS? #1
Tecolote
LS MT125
Hello all, I am new to this forum but have looked for an answer both here and elsewhere and could not find one.
So my question is: Can I use the NH Ambra Multi G-134 in my MT125 (should be the same) and if there is an issue down the road, not have LS tell me the NH fluid was not approved for warranty purposes? I do not have an LS dealer in my area, but there is a NH dealer within reach and that's the reason for the NH related question.
The NH hydraulic fluid container does not state it is GL4 or AW ISO 32/46 compliant anywhere and is curiously vague in its description of what it is approved for. I read that the NH fluid is good for hydraulic purposes as well as hydrostatic transmissions but if there is anyone with LS dealer expertise i would really appreciate some input since i am having a hard time finding the exact fluid the LS manual calls for. I am not concerned that the NH fluid costs more.
I was told this one "might" work, but still have reservations since I do not want to void the warranty (Triax Agra UTTO XL Synthetic Blend Premium Tractor Hydraulic & Transmission Oil - Extreme Performance - Replaces Most OEM Fluids)
   / Are NH oils/fluids approved for LS? #2
Been using NH oil in ls xr3135 0w-40 motor oil to keep turbo from Imploding in cold northern weather. Remember all of the NH tractors under 60 HP are LS MTRon tractors with LS Motors. Only the loader and ancillary equipment is proprietary to NH. Oils work fine. If I wasn稚 using NH then I would be using John Deere both companies have done extensive oil evaluations. Keep in mind LS has its own Hydrostatic fluid. I plan to use it too. Not all oils are created equal do your homework before having to replace components from oil failure. Cheap oils can do harm long term experienced this firsthand.
   / Are NH oils/fluids approved for LS? #3
Not all New Holland under 60hp, my boomer 54d has a fpt engine.
Thanks I appreciate the input. My logic is that if both the NH Workmaster 25S and the LS MT125 are identical because LS manufactures the NH 25S, then it stands to reason that the NH hydraulic fluid (Ambra Multi G-134) recommended for the NH 25S is also safe to use for the LS MT125.
John Deere 920 Platform (A50514)
John Deere 920...
2024 Isuzu NRR 24ft Box Truck (A50323)
2024 Isuzu NRR...
2012 Honda Accord Sedan (A50324)
2012 Honda Accord...
Kinze (Delgelman) MT 201 High Speed Disc (A52349)
Kinze (Delgelman)...
Skid steer auger plate (A50322)
Skid steer auger...
Grasshopper 722D Zero Turn Mower (A50514)
Grasshopper 722D...
