Are Hydraulic hses supposed to get hot?
   / Are Hydraulic hses supposed to get hot? #1
rixtory
Bronze Member
Bethlehem, PA
Kubota BX2200
I have a BX2200 with 357 hours and I have noticed that the hoses all get very hot, hard to touch sometimes. This is regardless of whether the FEL is attached or not. Is this normal?
Also I noticed that even after 2 hours of mowing my 3PH arms are even very warm..
Rick
   / Are Hydraulic hses supposed to get hot? #2
Yes, hydraulic fluid gets very hot when pumped to the pressures these tractors use. HST transmissions also contribute to the heat.
CR
   / Are Hydraulic hses supposed to get hot? #3
Yes, typically between 140-170F. Too hot to comfortably hold for a long time. If it is much hotter than that, your oil cooler may be clogged up with dust or chaff.
jb
NEW Wolverine Skid Steer Bucket Forks (A53002)
NEW Wolverine Skid...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
JOHN DEERE 5075GN LOT NUMBER 127 (A53084)
JOHN DEERE 5075GN...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
