That's the only answer to my problem I can come up with.
I am pumping from a rainwater cistern 5' deep to a pressure tank for watering a garden. Pump is set to cut in at 30 psi and out at 50. Cistern does have fine sediment in the bottom so I have inserted the dip tube/footvalve assembly in a 4" perforated plastic pipe wrapped with a sediment sock to act as a filter to minimize sucking up sediment.
Here's what happens:
When the pressure reaches 50 the pump cuts off as it should. When the pressure falls to 30 the pump cuts on also as it should BUT sometimes it does not pump water even though it is running. (The housing will eventually get warm if left running too long.) It may go through 6 or 7 on/off cycles successfully and then fail to pump water the next time the pump cuts in. Sometimes it is just 1 to 2 cycles before failure. I can use it only if I am present to tend it.
I have a filter between the pump and pressure tank and pressure gauges on both sides of the filter that read the same pressure so I know the filter is not clogged. I have removed the footvalve many times and when I turn it upside down I hear a click indicating it opens and closes. I have spent so much money and time to get this working it would have been cheaper to water the garden with bottled water.
Help!
