Are 790 P.B. Quick Connects "Standard"?
   / Are 790 P.B. Quick Connects "Standard"? #1
Phineas7
LaGrange, GA
JD 790
When I grow up I want to be like Mech! I got my power beyond kit installed. I have the same valve as Mech and I have a center link cylinder from C&C. Now I've got to start getting it all together.
So, to connect my valve to the PB; Are the quick connectors some sort of standard that any shop can get, or are they JD proprietary?
BTW Mech, if you catch this post; Is the valve PB ready? When I ordered it there was some mentions of a PB plug or something like that.
   / Are 790 P.B. Quick Connects "Standard"? #2
I bought JD quick disconnects because I had read that there were a lot of issues with compatibility. On my 790 the QD's to connect to the PB are much larger than the QD's used at the FEL disconnect point. I stupidly bought all my QD's (at the loader QD point and at the Blade Angle QD point) for the size to fit the PB which was probably more expensive and gave me larger QDs to deal with. If you get them at JD be sure to specify the QD at the PB or they will give you smaller "790 ones". That is what I got the first time and had to return.
The PB connects to the in/out on the valve w/o modification. The valve can have a PB run off of it also if you desire to add more hydraulic toys.
Enjoy putting this all together.
(APPROX 32) 6' X 12' HEAVY CHAIN LINK SITE PANELS (A54756)
(APPROX 32) 6' X...
UNUSED INDUSTRIAS AMERICA C18 CATTLE LOADING RAMP (A54756)
UNUSED INDUSTRIAS...
UNUSED LANDHONOR LDH-HT380 STAND ON SKID STEER (A54756)
UNUSED LANDHONOR...
UNUSED LANDHONOR LHR-RC920 CHAINS & BINDERS (A54757)
UNUSED LANDHONOR...
TAKEUCHI TB240 EXCAVATOR (A52705)
TAKEUCHI TB240...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
