nwngunner
I have been doing a lot of research and wanting a plasma cutter. How ever, i am finding a plasma cutter is very very touchy in what it will and will not work with. Most of the time i am not working with new clean metal, and there is no way to make some of the metal i work with shine like new.
So my question is, how effective is arc air gouging in rough cutting steel. How clean will it cut and how percise can i get with it, with pratice.
Also, i have a 300amp dc welder and my compressor will do almost 17cfm @ 175psi. Are those two items big enough, also how thick of steel can i expect to cut, or is it like a torch the slower i go the thicker i can cut. I am wanting to be able to cut up to 1inch or 1 1/4 plate some times.
Also what is required to be able to do this process, is just a arc air torch and connect my air line and my stinger lead to it?
