Aquiline Talons chains on a 3x20?
   / Aquiline Talons chains on a 3x20? #1
Oldtink
NW.PA
JD 3520
Is anyone running Aquiline Talon chains on their 3x20 series along with the wide R4 (15x19.5) rear tires?
I'm concerned about the clearance between the sidewall and the inside of the fender.
   / Aquiline Talons chains on a 3x20? #2
i am running them on much bigger tiresbut i'm looking at running them on my L3400 Kubota (i believe it shares a tire size with you) and the talons are only running down the center chain. The sidewall of the chain (so to speak) is just a standard chain. If you have clearance issues with that then it doesn't matter what the pattern is running down the tire. What I'm trying to say is thesidewall profile of the chain should be the narrowest hight of the chain (If it has v-bars or talon style lugs) how much room do you have from the sidewall to the nearest part of your fender? Whats the clearance between your tread and the bottom of the fender over the tire?
Thanks for your response. I have 2.5" between the sidewall and the inside of the fender and a minimum of 4.5" clearance on top to the tire to the fender. It's that inside clearance that concerns me and I already have the wheels in the wide position.
   / Aquiline Talons chains on a 3x20? #4
I can measure the height of the chain on my 16.9-30 tires to give you a rough idea of worst case scenario. The chain should be a little bit smaller on the smaller tires I would imagine.
Well, that would be certainly remove all doubt about clearance issues and be mighty nice of you to do so.
I appreciate your efforts.
   / Aquiline Talons chains on a 3x20? #6
the chains on my 16.9-30 tires stick out just shy of 1 and 3/8 inches, so I reported conservatively.
Ok, sounds like I'd have 1.125" clearance. Thank you so much for taking the time to get that vital measurement for me. Really apperciate it.
2018 MACK CHU613 DAYCAB WINCH TRUCK (A53843)
2018 MACK CHU613...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53473)
2006 Magnolia Dry...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
