Anyone using Mobil 424?
   / Anyone using Mobil 424? #1
tiogajoe
Little Marsh, Pa
Kioti CK2610hst
I'm coming up on my Hydro fluid service. I see Summit Racing has a great deal on 2.5 gallons of Mobil 424 for $32 after a $5 rebate. I'm thinking of grabbing 3 containers? I understand it's good stuff? Any Comments?
   / Anyone using Mobil 424? #3
I use it in my L3800 HST no problems at all .....
   / Anyone using Mobil 424? #4
It's the only tractor hydraulic fluid that I use. Probably have 6 or 7 buckets in the shop.
Check with your local Exxon-Mobil supplier. That's where I buy mine. I think it's right around $50 for 5 gallons.
   / Anyone using Mobil 424? #5
Did my 50hr last month - I did the fluids along with the filters - used Mobil424, have used it before most likely always will.......
   / Anyone using Mobil 424? #6
currently have traveller premium universal in one, and Mobil 424 in the other dk45se The 424 is noticeably better in sub freezing temperatures. While the Traveller is acceptable, as seen in an oil analysis I have after 400hrs on that fluid. I'll be interested to see what the 424 looks like after same hours. Ill be switching over one of the units to SUDT 2 this summer, and will do an analysis on this as well, after another 400hrs.
I think 424 is a great fluid based off the data sheet, what people are saying here, and my own experience. $65 for 5 gallons of 424 is a great deal.
   / Anyone using Mobil 424? #7
I bought this as well, the free shipping on that quantity was great. I never checked any local Mobil distributors as suggested.
Are you going use in your front axle as well? My dealer said mine was filled with gear oil, so I stayed with that, but would be nice to stock only a single fluid.
   / Anyone using Mobil 424? #8
I believe they come with Hyd/Trans fluid, but I don't replace with it, I use 90+ Synthetic gear oil, just more comfortable using that......
   / Anyone using Mobil 424? #9
I used 424 for a number of years in my Kioti. It worked well. On the last change I switched over to SUDT2. I believe it is slightly better in the cold winter time. But 424 is good.
   / Anyone using Mobil 424? #10
First Mobil 424 has a great reputation, I recently found a local supplier that has decent pricing and will likely switch to it in the future.
But my question is why many on here think gear oil in the front axle is necessary over the UTF almost universally recommended by manufacturers? If it is good enough to lubricate the transmission and rear end gears, why would it not be acceptable in a front axle which likely has less stress and likewise much simpler lubrication requirements?
I often see people saying use products which meet manufacturers spec but ignore their recommendation of UTF in the front axle in lieu of gear oil. I have used the UTF in my front axles just like what the manufacturer recommends with never a problem.
2016 Ford F-150 4x4 Pickup Truck (A44572)
2016 Ford F-150...
2018 TOP HAT  GOOSENECK TRAILER (A45333)
2018 TOP HAT...
2013 FREIGHTLINER CORONADO 122 SD (A45333)
2013 FREIGHTLINER...
Online Buyers Premium (A42021)
Online Buyers...
2007 Ford Taurus Sedan (A44572)
2007 Ford Taurus...
2005 Ford F-250 Pickup Truck (A44572)
2005 Ford F-250...
