Anyone using BX24 power beyond for other stuff?
   / Anyone using BX24 power beyond for other stuff? #1
RayBo
Hello all,
Have any of you used the rear hydraulics for something other than the BH? Considering a 3PH log splitter, lift cylinder for dump trailer, etc..
I know there needs to be an open loop as with the BH off, one hose couples to the other.. Also know there are open circuit and closed circuit valves, etc..
Anyone that has been there and done it?
Thanks,
RayBo
   / Anyone using BX24 power beyond for other stuff? #2
No matter what you do you will need an open center valve to control whatever you are going to connect to. Fluid must flow into that valve and out of that valve back into the tractor when the valve is in neutral.
2016 Chrysler 200 Sedan (A50324)
2016 Chrysler 200...
IH 810-10 Pick Up Head (A50514)
IH 810-10 Pick Up...
2015 MACK CXU613 TANDEM AXLE DAY CAB (A52141)
2015 MACK CXU613...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
MAHINDRA 2816 TRACTOR (A51243)
MAHINDRA 2816...
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
