Anyone used a Marine Tilt and Trim unit for a Front or Rear equipment lift
   / Anyone used a Marine Tilt and Trim unit for a Front or Rear equipment lift #1
kraftymate
Panhandle Florida
2010 John Deere 5045D w/512 FEL and 2003 New Holland TC33 4X4 w/FEL
Anyone used a Marine Tilt and Trim unit for a Front or Rear equipment lift, like to lift a plow blade or a tiller or snow plow, etc you get the idea?
I would like to mount one on my Garden Tractor as they are ALOT LESS than a tractor hitch.
Thanks a bunch guys!!!!!!!!
Kraftymate
   / Anyone used a Marine Tilt and Trim unit for a Front or Rear equipment lift #2
You will still need to mount the tank/pump combo. Where do you plan to put it?
   / Anyone used a Marine Tilt and Trim unit for a Front or Rear equipment lift #3
I used a marine set up for a plow idea on my rider mower. It did work with plenty of power but was slow going up and down. I mounted the pump/tank under the seat. Wireing the motor to switches was a little trickey.
Glenn
I had planned to mount a small compact tilt & trim unit on the rear on a custom made mount that can be unbolted and re-bolted to the front of the tractor.
I have seen several small T&T units that do not have a separate reservoir, they are self-contained and will lift a 200 lb. motor which my push blade or drag weigh even with weight on it. So it will be like a small sleeve hitch with the T&T unit mounted to it.
Think it will work?????
kraftymate
   / Anyone used a Marine Tilt and Trim unit for a Front or Rear equipment lift #5
You will need to consider waterproofing it. A normal marine unit expects to live it's life in a dry hot bilge area. I would spray it thoroughly with LPS-3 or similar waxy coating. The basic idea sounds good. Simple self contained 12v solution for a small need. It would require a 3 postion rocker switch; up-off-down. West Marine or Boat-US should have all parts you need, including a dash type rocker switch.
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
