Anyone use an Optima battery in a BX?
   / Anyone use an Optima battery in a BX? #1
drssg
Veteran Member
Ohio
Kubota M5700, BX2350
I'm not sure if any of their batteries fit my BX2350. Their D35 looks like a similar size to mine, but it's about an inch longer. It looks like it would fit, but it would be close. Is anyone here using an Optima battery in a BX? The battery size looks identical to a group 26R, but the manual lists it as a 526RA. I'm not seeing that battery type listed anywhere else.
I'm not dead set on Optima, but I've had one in my M5700 for 6.5 years, and it's still going strong - even with the recent single digit temps. The original battery in the BX was also good. It is a Deka, and it lasted for 7 years. I bought whatever was at TSC once, and that thing lasted 1 year, and it corroded like crazy. So I'm no expert, but I know they're not all the same. I'd like to get something that will work well for several years.
   / Anyone use an Optima battery in a BX? #2
Yup, it's a 26R
Size on mine when I measured it was about;
8 x 6-3/4 x 7-3/4
I wanted a larger one but couldn't find anything that fit, so I ended back up a 26R model.
   / Anyone use an Optima battery in a BX? #3
I had an Optima Red Top group 75/35 in my Ford 8N from Nov 2007 to Jan 2014, a little over 6 years. It worked well, but I ended up replacing it with a Diehard Silver due to availability and cost. The battery in my GR2120 is a group 51R, Diehard Silver is $110, Optima Yellow Top is $177. Guess I will have to make that decision then. Philip.
   / Anyone use an Optima battery in a BX? #4
I had an optima redtop last for over 12 years in my CJ-5. It only see's summer use here in Pennsylvania due to the excessive road salt, so the battery is removed and trickled charge once a month give or take in the winter months.
I replaced it with a yellow top, which is a dual purpose battery, which is intended for auto's with additional electrical accessories that are likely to put more demand on the battery that would exceed the alternators output at various times(Spot lights, stereo's, winching, or even that parasitic drain from a clock, etc,) I would also consider long periods of inactivity for this battery.
I have a blue top in my bass boat on the deep cycle side..
here is a quick video to ensure you get the right one for your usage..
Difference between Red Top, Yellow Top and Blue Top Optima Batteries - YouTube
   / Anyone use an Optima battery in a BX? #5
I have an Optima in my B7800 as well as a very small hot rod I have. The hot rod has one of the smallest batteries I have ever seen and I believe had a Honda car use origin. If you need the group number I can get it. It doesn't look big enough to start a car but it does. I bought it mail order from Summit Racing and you can find any of the Optima batteries there.
The one in my B7800 is a number of years old and just keeps going. I do charge it in late fall so it goes into winter in good shape and zero problems.
   / Anyone use an Optima battery in a BX? #6
Optima makes a great battery. I use them in my Jeeps and Buggies. Best part about them is no rust from leakage, even upside down. I used to have a dual battery system on one Jeep with Optimas, laying on their side. As mentioned above, you probably just need a red top. Yellow tops are what I use with winches. Blue Tops are designed for deep cycle use such as a boat trolling motor.
   / Anyone use an Optima battery in a BX? #7
I use to be a huge Optima fan in my boats, trucks and jeep, but noticed a drop in performance over the years especially in NH winters... I'm now a Sears Die Hard fan (particularly the platinum series) and have phased out all optimas and have had NO issues over the past 4 years..
Running pairs in my offroad jeep and full size chevy.
Odessy Batteries are great batteries too. They are essentially a die hard platinum. Made in the same factory...
BTW special note for those who use batteries with both side and top battery terminals. ONLY the Die Hards / Odessey are rated for full amperage on the side terminals. Optimas are not (its in their paperwork) and can meltdown with high amps. This is more for the jeeping / truck guys... Just an FYI...
   / Anyone use an Optima battery in a BX? #8
+1 to FFK
Whenever I replace a battery on anything that I deem as mission critical, I use the Starved Electrolyte (AGM) type by Odyssey, and maintain it with a smart charger/maintainer.
And yes, the Sears Diehard Platinum series is a rebranded Odyssey.
   / Anyone use an Optima battery in a BX? #9
What is a Buggies? A VW Bug?
   / Anyone use an Optima battery in a BX? #10
I use a single Optima in my Jeep. I'll be changing out the boat batteries this year and putting in 2 optimas. One for starting and a yellow top for the house battery.
I may be putting an Optima in the Kioti IF I can find one with higher CCA's than what I already got.
John Deere D105 (A44502)
John Deere D105...
2014 FREIGHTLINER CORONADO (A45046)
2014 FREIGHTLINER...
CHECO HYDRAULIC GREASE INJECTION UNIT (A45333)
CHECO HYDRAULIC...
DEWALT ROTARY HAMMER (A45333)
DEWALT ROTARY...
2019 Chevrolet Tahoe SUV (A44572)
2019 Chevrolet...
MIKASA MTX-60 PACKER (A45333)
MIKASA MTX-60...
