deezler
Elite Member
- Joined
- Jan 30, 2012
- Messages
- 3,571
- Location
- Southeast MI
- Tractor
- Cub Cadet 7305, Kioti CK3510seh TLB
Hi all,
I am kind of a newb when it comes to hydraulics and snow plow technology, so bear with me here.
A friend of mine just picked up a worn out jeep that came with a Meyer snow plow and the e47 electric pump / lift cylinder. He is parting out the jeep and has no use for the plow setup, might offer me a good price on it. I am intrigued about the possibility of setting up a FEL mounted plow for my long driveway. I don't have a quick attach loader/bucket, but I wouldn't mind going to the trouble of swapping pins to mount a plow frame during the snowiest months.
My question is this: has anyone ever used an electric hydraulic pump for their FEL plow setup, for the angle cylinders? From my searching is seems like everyone uses the tractors hydraulics for the angle cylinders, off a rear remote, usually. I know this is probably the best solution, but my tractor has no remotes currently, and that seems like a pricey option to include in this venture.
So I was pondering just wiring up the electric pump and switches, and use that for the angle cylinders (provided I can figure out how to get a mounting system welded up). However it seems like the Meyer e47 draws a TON of amps. Like 150, or something nutty like that. My lil' tractor only has a 40 amp alternator and smallish battery - could it handle an electric plow pump?
(Sidebar: does the pump only run when you lift or angle the plow, or does it run continuously?)
Thanks for any advice!
