Pat's Easy Change Anyone use a Pat's weld-on style easy change?
   / Anyone use a Pat's weld-on style easy change? #1
GreenTime
Bronze Member
North Dakota
JD 110TLB, JD 3720, JD Z997, Kubota L5740
I have a Kubota L5740 with adjustable lower links. I am thinking of going with his weld-on style so I have a more solid mount and don't have to deal with the 3.5" longer length. Anyone else use the weld-on style and your comments would be appreciated. Thanks.
   / Anyone use a Pat's weld-on style easy change? #3
I don't have Pat's weld on but I do have his removable. A bit of caution is advised here. Be really SURE of your alignment. I put mine on and the squared them up but the wouldn't fit my implement. They had to be square with the implement to be used. If all are the same width there should be no issue. I have different width implements so the attitude adjustment is necessary for me.
   / Anyone use a Pat's weld-on style easy change? #4
I did the weld on euro style hooks. I prefer the ball and socket connection to the pin and hook on the Pats system since there is less slop, but still with the full range of motion. If you don’t mind welding and not being able to switch back I think either style hook is a better more solid connection than the Pats pin on.
I am assuming that tractor is Cat 2 so you should be fine with the 2/1 hooks that agristore USA or that Mr FitRite Hydraulics can provide. If I was going to do it again I might try to find a true Cat 1 hook since I have a smaller tractor and tend to have smaller implements. The euro hook requires more clearance room behind the pin than the Pats system, and I found my brush hog has some minor interference. The euro hooks would also be compatible to a similar category sized one piece quick hitch.
More info coming soon! (A49346)
More info coming...
2014 Dodge Grand Caravan (A50324)
2014 Dodge Grand...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A52128)
2019 Energreen EVO...
UNUSED FUTURE MINI EXCAVATOR HYD WOOD DRILL (A51244)
UNUSED FUTURE MINI...
2239 (A51244)
2239 (A51244)
