Anyone use a leaf truckloader with an RTV900?
   / Anyone use a leaf truckloader with an RTV900? #1
baddaddy
Norwell, Ma
Kubota B7610HSD, Kubota RTV900
A couple years ago made a leaf vac system from a MacKissic VCB1100 motor & rotor by fabricating a frame for it and mounting it on the side of my RTV900. Worked reasonably ok for a couple years but then the motor crapped out because of a stupid mistake I made when replacing the chipper weldment. Now I'm looking at something like the Little Wonder 14HP on a small tow behind single axle utility trailer. Not the cheapest solution but I have a boatload of leaves and debris to clean up every spring and fall and I don't think I can go back to dragging tarps of leaves again. Anyone done something like this? They make truck mount and hitch mount systems, but I think the 225lbs of the smallest little wonder truckloader would be a bit much for my RTV900, hence the small utility trailer tow behind solution.
3in Poly Pipe (A49461)
2020 CASE CX37C EXCAVATOR (A51242)
2020 CASE CX37C...
2009 PETERBILT 388 TANDEM AXLE DAY CAB (A51219)
2009 PETERBILT 388...
1982 LeeBoy Motor Grader (A51039)
1982 LeeBoy Motor...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
John Deere Ztrak M665 60in Zero Turn Mower (A48082)
John Deere Ztrak...
