Rake Anyone try this with a landscape rake?
   / Anyone try this with a landscape rake? #1
CVHoss
S.E. Kansas
J.D. 4400
In my back yard project, I had two buildings bulldozed down. These were old horse barns that had partial brick floors. I've ended up with a lot of bricks and brick sized chunks of concrete left in the area. I've tried using the box blade and the landscape rake to move them out, but I seem to drag more dirt than I do bricks. I started thinking about removing every other tooth on the landscape rake so that the opening would be a little larger (2" instead of 1") and hopefully, let the dirt flow through but retain the bricks and concrete chunks. Thought I'd check to see if anyone had tried it before I started pulling teeth.
Thanks,
Hoss
   / Anyone try this with a landscape rake? #2
Interesting concept. I understand the problem completely though. Had the same problem raking my land to get up the vines and final pieces of wood around it after discing and blading. If a big enough piece was gathered in a lot of dirt built-up in the rake.
Be intersted what you find since I have a lot more land to clear.
GS
   / Anyone try this with a landscape rake? #3
A freind had the same problem with a 4 foot rake he had on a wider tractor so to kill 2 birds with one stone i fixed an extension on each side and took out every other tooth then added them to the sides he now has a a properly sized rake and is lets the dirt go through it. whes now raking up spme bricks for me on a backhoe job.
   / Anyone try this with a landscape rake? #4
Hoss, your idea sounds like it might work. Regular stone forks, designed for what you're doing, are spaced 2 to 3 inches, sometimes more. I got a stone fork a few months back, but I was going for small stuff too. Here's a link to an older page showing my forks, just for comparison. Since this page was posted, I've collected tons more rocks. Best of luck.
http://home.earthlink.net/~jonathanfarms/StoneFork.html
2018 John Deere 331G Compact Track Loader Skid Steer (A50322)
2018 John Deere...
UNUSED AGT YSRT14 STAND ON SKID STEER (A51243)
UNUSED AGT YSRT14...
New Holland 477 Swather/Mower Conditioner (A52128)
New Holland 477...
2008 Suzuki XL7 SUV (A50324)
2008 Suzuki XL7...
UNUSED JCT QUICK ATTACH 72" HYD 4N1 COMBO BUCKET (A51244)
UNUSED JCT QUICK...
J & M 30' Head Cart (A50514)
J & M 30' Head...
