I am looking at buying a PX1153PC for my 180 farm. I would use it for mowing (batwing), loader work, subsoiling, pasture renovation, hay production, etc. I have been comparing to JD 5100M and 6110M tractors. Any one using the PX 1153 have any thoughts or advice ?
First of all, the JD-M series is a whole different animal with their full frame design. Built for loader work.
Now to my story. I still think I'm overpowered and wanted to step down from a 6430 premium. I had something to pick up at Kioti dealer and took one for a short test drive. Their turning circle is incredible over the JD due to the different front axle design. The way I understood the advertising, they don't use a DPF filter, just a DOC with urea. But it seems like the Doosan engine is somehow restricted in the power when not fully warmed up and the DOC works properly.
The transmission shifts smooth and easy. The gear leaver and loader control are a little bit turned outwards. That means, they are layd out more ergonomically and are easier to push or pull that way.
What I found, the loader arms are mounted very low on the tractor compared to JD. This is blocking the view on the loader bucket on the ground when you look down between the hood and front wheel. The loader on the JD is way faster due to a higher gpm output on the hydraulics.
I've contacted a friend of mine regarding that 3.5 ltr Doosan engine. He is selling Doosan heavy equipment in Germany and got first hand info from Doosan. They had issues with fuel management and some engine control. Those issues should have been solved by Doosan on engines built in the 2nd half of 2016 or later.
The after treatment is not covered under the 7(?) Year powertrain warranty, regarding my dealer.
I hope this does help in making your decision.
I still hang on to my 6430. It is beefier and at this point, there is not a big financial difference in the payments. It's not worth it to trade or change.
If you compare the Kioti to a 6110M you will see a big difference in the new purchase prices.
