Anyone rebuilt a Hydrogear Hydrostatic Drive
   / Anyone rebuilt a Hydrogear Hydrostatic Drive #1
samission
SW OH / Xenia
CASE DX33
Hello Everyone,
Been a while since my last post, but I am looking for some help with a HydoGear BDU-21L-110 transmission.
I know that it is going to have to be rebuilt, I have been nursing it along for a few years now. My biggest mistake was allowing a friend to look at it, he assembled the pump section backwards, ran it on the tractor for about 5 minutes before he realized something was not working right.
I just tried to buy a new one to replace it, but Hydro-Gear says they no longer have new ones and do not do factory service on them anymore either. I have now decided to do the rebuild myself, especially after what happened before, as I have had this one apart a couple of times since, without any problems, just not making much of a difference in performance.
Now for the problem,
It no longer has much power, especially with the C-Section (center section) gouged where the pump cylinder block was put in backwards. When using the tractor/mower on flat ground it does OK, but not great, but if you try to go up a small incline you may have to resort to pushing. The transmission is making a whining noise like there is not enough pressure in the system, or the pressure is being bypassed, almost like a relief valve stuck open. I have looked at both the left and right relief valves and both seem to be working OK, I'm assuming that the bypass is probabily through the gouge in the C-Section. I am looking for suggestions from someone who has worked with theses units as to what usually needs replaced in a rebuild of the transmission.
My best option I think, is to replace the C-Section, Motor and Pump Cylinder Block Assemblies, and the guts of the charge pump.
Thanks in advance for any help, as I will be needing to use it soon and without a steady income now, buying a new unit is out of the question.
Thanks again,
Steve
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
2008 Caterpillar 303.5C Mini Excavator (A52377)
2008 Caterpillar...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
2008 Komatsu WB146-5 (A47477)
2008 Komatsu...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A54313)
2016 WESTERN STAR...
