Anyone know where I can find some clamps like this
   / Anyone know where I can find some clamps like this #1
MikeFromVA
Where VA, WV, and MD meet
John Deere 4110
I'm trying to mount some torches to my deck. The torches are on 1" bronze poles and I need some clamps to mount to my deck rail supports to hold them. I think that they should look like this (except these are for 3" pipes).
OR
I need them to stand off of the post by about 3/4" to 1" to clear the post cap.
Any help would be appreciated.
   / Anyone know where I can find some clamps like this #2
Perhaps you could follow the path of JasonL in this thread? We could then have a thread about the world most expensive "Tiki Torch" brackets! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Oh....also, I don't know where you could buy those brackets....sorry.
Dave
   / Anyone know where I can find some clamps like this #3
? - Screw a 1 1/4" steel pipe flange to the deck, and use a 12" piece of 1 1/4" pipe to hold the torch at the base? You could unscrew the pipe piece when you want it out of the way.
   / Anyone know where I can find some clamps like this #4
Mike,
Try Austin Hardware www.austinhardware.com
If you don't see it on their web site (everything's not on the site), call them or get their catalog (which is almost 900 pages of pretty much just hardware).
Brian
   / Anyone know where I can find some clamps like this #5
It will not colour match but perhaps some paint.
pipe flange on post - short - threaded nipple - tee on other end of threaded nipple fot the lamp post to go through. Might be able to mix galvanized to cpper pipe for neater look if there is clearance.
Welder ?
Block of wood with large stainles steel hoze clamp ?
Egon /forums/images/graemlins/grin.gif
   / Anyone know where I can find some clamps like this #6
You might not get the exact same design, but check places that sell outdoor TV antenna poles. I bought something slightly similar at Radio Shack a few years back to anchor mine.
   / Anyone know where I can find some clamps like this #7
Not being sure of where you want to attach....ie: top rail, bottom rail, inside or outside of rail. Is the pole about 4-5ft long like most?
With that, here is my thought.... a 1/2 round bracket of what ever size/diameter you require attached to the outside or inside of both the top and bottom rail. like the copper brackets used to secure plumbing copper. It could also be plastic or galvanized strap and all could be painted to blend.
The idea of the brackets/straps is to reduce the potential for being seen. There are also decorative curtain rod holders made of various materials that could work also.
Eye hooks of appropriate length screwed into the rails or posts and painted to blend is another option.
Hope this helps some
Thank you for the advice everyone. - I was hoping to find something standard but now it's looking like I will have to invent something...
   / Anyone know where I can find some clamps like this #9
You could use pvc pipe... like they do to hold fishing poles.
   / Anyone know where I can find some clamps like this #10
Ya beat me to it!
Soundguy
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A53426)
2023 PETERBILT 579...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53473)
PENDING SELLER...
Kenmore KLFC015MWD0 Deep Freezer (A53117)
Kenmore...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A51246)
JOHN DEERE 437E...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
