Anyone have info on a Ford 1200
   / Anyone have info on a Ford 1200 #1
SteveM
Upstate NY
Kubota B7100DT
Looking at a Ford 1200 4wd; wondering if anyone has any info - I know the HP and weight, etc - wondering about lift capacity, parts avail, etc.
Also found a Ford 1100 - seems the 1100 is slightly newer, with the headlights in the fenders, and the 1100 actually looks a little bigger...?
Thanks for the help!
   / Anyone have info on a Ford 1200 #2
The only thing I would have to tell you is that some of the parts for this model are getting a little tough to get!
   / Anyone have info on a Ford 1200 #3
There is a little bit of information on this forum re: the 1200 and the 1100. I did a search on this forum with "Ford 1100" and "Ford 1200" and found a few post, mostly mine! /forums/images/graemlins/wink.gif
Seriously, the Ford 1100 I grew up with was a tough little tractor which I enjoyed immensely. The tractor was made by Shibauru, I believe. For either the 1100 or the 1200 you would be limited to 4' implements.
I wish my Dad wouldn't have sold it, to be honest. Although there is no comparison between it and the TC 40D he now has! /forums/images/graemlins/laugh.gif
Dad didn't have any problem getting a new radiator in 2000 when he jammed a stick through it. He was trying to take care of his new property . . . 44 acres! /forums/images/graemlins/shocked.gif Not big enough!
The tractor, that is.
It was just dandy for 4 acres. Hopefully the new owner is getting the same service out of it that we did.
   / Anyone have info on a Ford 1200 #4
I think that the 1200 is a later addition to the rest of the Ford compacts of that era. The Ford literature that I have is missing the 1200. The model line is 1100, 1300, 1500, 1700 & 1900. I was forced to use other research means.
Ready? Here are the stats:
The 1200 was produced from 1980 to 1983. It uses a 49 cubic inch, 2-cylinder engine with 13.5 PTO hp. The transmission has 10-speeds forward and 2 reverse. Weight is 1,244 lbs. No info on the 3-pt. lift capacity.
JOHN DEERE WHEEL LOADER 71" FORKS (A51246)
JOHN DEERE WHEEL...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
2017 FORD TRANSIT T150 CARGO VAN (A52577)
2017 FORD TRANSIT...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
City of Buckhannon - 2014 Ford Fusion SE (A52384)
City of Buckhannon...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
