Anyone have a trencher
   / Anyone have a trencher #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Was looking for thoughts. I need to lay around 200 feet of pipe and electric, trencher costs 500 a day to rent. Thinking about rigging up a used Toro Dingo trencher I found online and for its cost It would pay for itself in 2 days.
But, driving backwards, trying to trench.
   / Anyone have a trencher #2
I don't have a trencher, but was also thinking of getting one for my 425. PJ (RIP PJ), had one on his PT425 out in Montana. He used it quit a bit and found no problems driving backwards to pull the trencher. You aren't going at any kind of speed where you're going to ram into anything. I don't think it would be much of a problem at all. I'd think about marking out the trench line with some orange paint and then just aiming the rear of the machine towards that line as I went.
I did pull in 100' of water line with a homemade pipe puller. To get near the house, I had to do that one backwards and it was no problem at all.
   / Anyone have a trencher #3
We laid 1700ft of 2" main line PVC sch 40 for our place.
Rented a trencher for that but rented a Ground Saw for the arteries to
feed all the rotors.
Now THAT'S Florida where if you're 3"-6" you're out of the frost zone.
Let's just say that your depths may vary :laughing:
I'd never consider buying and that was 10 yrs ago.
Now? I'd pull Flex PVC trough the ground with my tractor from a spool with a sub-soiler plow.
But that's just me.
Installing Water Lines with a Subsoiler - YouTube
DIY Underground Wire layer/Pipe layer - YouTube
Siromer pipe layer - YouTube
Farm Tech Supplies RP1 Ripper and Pipe Layer - YouTube
   / Anyone have a trencher #4
I have one. It has a practical depth limit of about 24 inches. I have used it for several thousand feet over its 17 years of use. Generally I am pleased with it. Issues and concerns are:
1. You have to put oil on the chain every 20 minutes or so. Not a big deal, just do it.
2. The chain has to be tightened occasionally. Just like a chain saw.
3. It does about a yard every three minutes. Just a guess, it is slow, but not a big deal.
4. It is kinda jerky.
5. When you try to go below 18 to 24 inches is gets slower.
6. It is a little hard to keep it down. So the bottom is not completely even.
7. The trench will not be perfectly straight.
I have not used it lately, but I would say two thirds of my use has been for other people. I have a lot of people who owe me in the area. That is a good thing.
These are not big problems and I would buy it again. Oh, it has a life of about one mile per Terry I believe. I am at least two thirds through that.
   / Anyone have a trencher #5
I'm bummed to hear the practical limit is only 24" or so. That would be fine for wiring, but water lines here need to be down around 54" as I recall.
   / Anyone have a trencher #6
I rented a large walk behind trencher to put in about 230 feet of conduit/conductor from a pole to my cabin. I got it done in a day. The soil was rocky, and the trencher jumped around like a bucking bull. It beat me around so bad I felt like I had been in a wrestling match all day. If you have a lot of rock, my advice is to get a small backhoe. If not rocky, a trencher will work fine. If sandy and not rocky, a subsoiler and pipe layer attachment should be ok.
Because I have the larger machine, I am thinking about getting a used toro dingo or bobcat trencher head and adapting it. For the moment I am looking to run a bunch of stuff in one trench (water, septic and power) to a shop. I have used a sod cutter and pulled just water but that won't work with septic. 250 feet. A ride on machine is $500 a day, $300 for a pusher. A used trencher is $1500 to 2K. Doing a walk behind sounds painful for sure.
I do have a backhoe but would like to get this done in my lifetime. Then again, whats the rush, right? Save myself the $2K and make a wider and potentiall deeper trench....
   / Anyone have a trencher #8
I trenched over 2000 feet in sand. After renting most rental units that all got stuck and buried in the sand I bought an attachment for my track loader.
The attachment cut liek a hot knife through soft butter and never got stuck once. The wide tracks floated over the sand and trench as needed.
It paid for itself in the first moth, then I sold it for darn near what I paid for it.
   / Anyone have a trencher #9
54 inches is out of the question. Frost line is 18 inches here.
   / Anyone have a trencher #10
We have rocky soil here. I hand dug my first trench on this property - 9" wide 20" deep and 33 feet long. Took 3 days in the middle of the summer. Still had a few other trenches to dig here & there, spaced out over the next few months. Went out and bought a backhoe for the tractor. Ended up with a lot more projects than I'd expected. It paid for itself in rental fees or hiring it done many times over.
2005 Thompson 4DDL-725 4in Double Diaphragm Water Pump S/A Towable Trailer (A46683)
2005 Thompson...
Ford 8N PARTS ONLY (A47371)
Ford 8N PARTS ONLY...
TOFT CAT315 HD 45" Excavator  Bucket (A49251)
TOFT CAT315 HD 45"...
2020 Ford Transit 350 Passenger Van (A46683)
2020 Ford Transit...
Bush Hog (A49251)
Bush Hog (A49251)
TPM 16 Mini Excavator (A49251)
TPM 16 Mini...
