Anyone have a slip clutch on their fx24d?
   / Anyone have a slip clutch on their fx24d? #1
ponder
Hi -
Just read some posts about the usefullness of slip clutches to prevent damage to transmissions of tractors using tillers on rocky ground (which is all there is in most of middle Tennessee...
Has anyone out there installed one of these on your tractor? Did it require any adjustment or new purchase of pto shafts?
Where did you buy it...is the one listed on TSC an appropriate one for the fx24d, or is there a supplier here on TBN I could order from?
Thanks!
Joel
   / Anyone have a slip clutch on their fx24d? #2
I used a slip clutch on my tiller. PTO shaft needed to be shortened, since that tiller sits pretty close to the rear tires. Works/ed great.
BTW, I needed to grind a grove into the splines on the tiller shaft to lock the slip clutch. Took all of 5-10 minutes (that included finding the grinder.)
thanks!
The pto shaft that came with my tiller is one of those 2 piece deals that can be adjusted for length up to about 6 inches...the ones that only go together one way? Does anybody know what i'm talking about...I'm at work, otw I'd post a picture...anyway, it looks like there'll be enough room to add the slip clutch and cut down on the extension of the 2 piece shaft.
Thanks for the tip about grinding the shaft!
Joel
JOHN DEERE 560M LOT NUMBER 37 (A53084)
JOHN DEERE 560M...
New/Unused Radiant Cooktop (A51573)
New/Unused Radiant...
2023 JOHN DEERE 8R370 LOT NUMBER 200 (A53084)
2023 JOHN DEERE...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
PRO WORKS PWFF LOT NUMBER 156 (A53084)
PRO WORKS PWFF LOT...
2015 Ford F-550 Auto Crane 4004EH 4,000LB 2 Ton Crane Service Truck (A51692)
2015 Ford F-550...
