anyone familiar with high ranger bucket trucks
   / anyone familiar with high ranger bucket trucks #1
spo307
Levittown & Long Eddy NY
kubota L4400
wrong fluid was put in aw46 hydraulic oil is too thick to pass port holes from pistol grip tubing, i was told to drain change filters and fill with ATF, this boom will be used for siding and roofing, no electrical work, sound correct
   / anyone familiar with high ranger bucket trucks #2
I could see this happening in winter but it should not be a problem in summer, the 46 is a 15 wt oil. I would contact High Ranger they were very helpful to me a few years ago with hose specs. CJ
thats what i am gonna do thanks for the reply
I contacted terex which now owns hi ranger aw 46 is a 20w oil, port holes in valves from pistol grip are small, fluid is too thick to pass fast so bucket controls are slow or dont work
   / anyone familiar with high ranger bucket trucks #5
AW32 is approximate a 10wt oil, AW46 is app a 15wt oil and AW68 is app a 20wt oil. Trans fliud is about a 7.5 wt. If you feel this will fix the problem go with whatever is cheapest. Just a FYI dextron 2/3 is the only oil Dennision recommends for their piston units, that is what I would use if you go with trans oil. Let us know the results. CJ
ATF? I have heard hi ranger oemm fluid is mil spec 5606, but at fluid change they use atf due to cost, my neighbor has a 1976 hi ranger and uses hy tran $32 for 5 gallons
   / anyone familiar with high ranger bucket trucks #8
Dextron 2 or 3 I think they are up to 4 now, it is a GM auto trans fluid. Didn't you post say they suggested it? CJ
   / anyone familiar with high ranger bucket trucks #9
Dextron XI is the latest
7066 (A39855)
7066 (A39855)
Allis Chalmers Rear Wheel Weights (A39855)
Allis Chalmers...
2015 T800 GIN POLE TRUCK (A41853)
2015 T800 GIN POLE...
2014 Nissan Altima Sedan (A42744)
2014 Nissan Altima...
Pronovost P-516 12ft T/A Dump Trailer (A42742)
Pronovost P-516...
Skid Steer 76in. Single Cylinder Skeleton Bucket (A39855)
Skid Steer 76in...
