Anyone experienced increased NO2 emissions on modern tractors with DPF?
   / Anyone experienced increased NO2 emissions on modern tractors with DPF? #1
Windblown
Bronze Member
Star Tannery VA
Bobcat CT2035
I would be interested to know if others have run into issues with lung irritation/inflammation on newer emission controlled tractors that have a DPF system installed. I picked up a new tractor about 7 weeks ago and have put 60 hours on it so far. It's a diesel unit with DPF. I noticed a rather pungent smell coming from the exhaust (which NO2 has) while operating the tractor off and on from the beginning that I never noticed on any of the non-emission controlled tracts I have owned.
I found that after a few hours of operating the tractor that my throat was getting sore and felt a mild burning in my lungs along with a headache and stuffy nose which it turns out are all symptoms of high levels of NO2. I thought at first it might be unrelated to the tractor at all and instead be an allergy. Yet on days when I was outside working but not on the tractor I was not experiencing any trouble. This came to a breaking point early this week when after a long day on the tractor with about 7 runtime hours I felt quite ill and that night I had a terrible dry cough to go along with the sore throat and burning lungs. I got very little sleep and by the morning added heavy chills which turned out to be from a 101 degree fever. When I started coughing up phlegm with blood in it I went to an Urgent care to see what was up.
The urgent care checked for Covid, flu, & strep but all those were negative. They concluded that I had an unspecified viral respiratory infection and prescribed Albuterol and Prednisone and sent me on my way with instructions to return if no improvement was noted in the next few days. When asked they said environmental pollutants could cause the symptoms but it could also be the infection made me more sensitive to environmental factors.
It's now the evening of the following day after my Dr visit and two days off the tractor. I'm feeling MUCH better. The fever is gone, sore throat almost gone, and coughing very little and only occasionally is is spotting with blood when I cough some phlegm up. At the moment the question remains of which came first, the infection or the irritant/pollutant?
My plan is to stay off the tractor for a few more days and if then feeling completely well I'm going to put another long day of work on the tractor. I have a lot of tractor work to do and I also want to see if I develop the same symptoms again. If I do my next step will be to see the doctor again and also approach the dealer with what is going on and ask them to test my tractors NO2 output levels. Hopefully that's something they can do. I've found an NO2 detector on Amazon but it's $800 bucks and I'd prefer not to pay that to test it myself if possible since even if it shows a dangerous level it still will be up to the dealer to resolve it.
I know folks will likely be curious as to the tractor brand and model but at this point the reason I'm not mentioning the brand and model is that it's entirely possible that my suspicion that the tractor is producing excessive amounts of NO2 is unfounded and I don't want this to turn into brand bashing or be accused of brand bashing. I just want to be able to use my tractor and would like to know if anyone else has noticed similar issues on DPF equipped tractors. Hell, maybe I've suddenly become allergic to diesel fumes?
I promise I'll follow up with more info on my situation as I get it. Thanks in advance.
   / Anyone experienced increased NO2 emissions on modern tractors with DPF? #2
If the DPF is catalytic, that may cause higher NO2 emissions
   / Anyone experienced increased NO2 emissions on modern tractors with DPF? #3
Stop running the tractor in the barn with the doors closed
and don't drink battery acid it's also bad for you....
   / Anyone experienced increased NO2 emissions on modern tractors with DPF? #4
If it didn't have DPF the NOx emissions would likely be much higher but yes, diesel exhaust is loaded with NOx even with DPF. I'm curious why you are smelling exhaust fumes while running the tractor? Manufacturers go out of their way trying to get the exhaust away from the operator. Sounds to me like your mission instead of going down the NOx rad might be to do something to get your face out of the exhaust path. I've been running tractors for 60 years and I don't think I have ever had one that blew exhaust in my face or made me sick. I did have a track loader that almost killed me doing it.
BTW, if you get a detector it needs to be a NOx detector that tests for all the NO compounds. NO and NO3 is likely more toxic than NO2. But save your money because they are all there.
Noted. I should have known racking up hours sitting in the barn was a bad idea. LOL. Battery acid? Is that code for moonshine? :)
I have heard either may be possible from multiple sources as far as total NOX output. Apparently if the engine is designed to normally run at lower exhaust temps then the extra NOX produced in the process of burning off the built up particulates in the DPF filter during regen is still less overall than would be produced without it. However it sounds like exhaust gasses are often intentionally kept high on tractors to reduce particle build up in order to reduce the number of times a regen is required. Mine has never yet lit the regen light indicating it needed to enter a regen automatically because of a detected pressure differential across the DPF filter. It does produce a bit of vary noticeable smell for a minute occasionally when at high RPM under load after a period of time doing lower rpm back and forth loader work which I assume is the exhaust gas reaching a high enough temp to burn some of the particulate matter out of the DPF without regen. Other times the smell is much less noticeable. After the trip to the doc I did fire it up (outside...) and after it warmed up I started a regen cycle manually and let it do it's thing while I was inside and then came back out and shut it down on the chance that it clears it out.
As for why I'm smelling it so much on this tractor versus the ones I've owned before? I dont know for sure. A couple old ones had the old fashioned stove pipe exhaust which tends to get the exhaust out over ones head. The last tractor before this one discharged the exhaust low up by the front left side of the tractor at I believe a downward angle but I'm not positive as I never had an issue with the exhaust and didn't think much about it. This one also discharges the exhaust low up by the front left side of the tractor but the tip bends to shoot the exhaust out to the side a bit.
Still waiting for no blood to show up in my phlegm in the morning after I get up before I get back on the seat to see what happens.
   / Anyone experienced increased NO2 emissions on modern tractors with DPF? #7
If I leave the EV runnig with the garage door closed, it gives me a headache🤯
   / Anyone experienced increased NO2 emissions on modern tractors with DPF? #8
NOx is produced in the combustion chamber, not so much the exhaust, the EGR is there to reduce the NOx by reducing combustion chamber temps via introducing the spent exhaust into the intake.
   / Anyone experienced increased NO2 emissions on modern tractors with DPF? #9
Quit sucking on the exhaust pipe... One, makes you ill and 2, will burn your lips...
   / Anyone experienced increased NO2 emissions on modern tractors with DPF? #10
LOL...DPF deals with particulate matter, sequestering it and then burning it off.
The SCR is what injects UREA and counteracts the high Nox buy chemically adding an extra nitrogen atom, changing it from introitus oxide to nitrous dioxide. .
If your tractor does not have SCR, you have nothing to deal with Nox.
2019 Kubota F3990 72in. Commercial Mower (A46684)
2019 Kubota F3990...
2004 Dodge Dakota Ext. Cab Pickup Truck (A46684)
2004 Dodge Dakota...
Cosmo 3pt, PTO Spreader (A47371)
Cosmo 3pt, PTO...
2021 Chevrolet Tahoe FL SUV (A48082)
2021 Chevrolet...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A46684)
2016 Chevrolet...
(2) 200 Gallon Oil Tanks (A47369)
(2) 200 Gallon Oil...
