Anyone ever tackled building a power rake?
   / Anyone ever tackled building a power rake? #1
wildcattdw
I have been pondering building a power-rake for some time. It all started with pondering purchasing a power rake, but the cost is prohibative, and I think this would be a fine winter project.
Some of the reasons I'd build -
I'd like a towable unit - this spring I helped my brother-in-law and seven of his neighbors power-rake and plug aerate their yards. That danged (pardon my foul mouth) power rake was a bear, and at $110/four hours, the cost to build seems pretty reasonable. The only towable unit I could find online was from BlueBird, and costs something like $1400, with spring-tines.
Simplicity - There's nothing to these things. A spinning bar with ~100 flail blades, the fabrication would get monotonous, but not difficult. I have a drill/mill, and with a simple jig, balance shouldn't be to bad.
So, has anyone ever built one? Any ideas?
In a week or so, I'm going to build a workbench and a welding cart for the TIG/ARC. I'll try to take some pictures of those to share...
T
   / Anyone ever tackled building a power rake? #2
There have been a few in Farm Show magazine. They sell a CD which covers many years of farm inventions. Look for a junked hay conditioner & you would have a pretty good start. Mike
   / Anyone ever tackled building a power rake? #3
I have been gathering right now I have thebearings and all the dimentions of a Harley rake teeth were 8.50 each and needs 88 of them. I looked at their teeth with the carbide tips and they look mighty familiar as in I knew I had seen something with a similar end that was often dicarded. Then it hit me as I had seen the tips fom an asphault milling machine and road stabilizing machines. they are bullet shaped with a narrow ring cone shape that a chopsaw can cut. The cutters are chunked every few days THiers a company nearby Ive dealt with the maintenance man for a few buckets of them in trade for the scraps.Ill probably have around 3 to 400 in the whole machine.
I plan on sticking with the KISS theory. The flail blades are going to be either 1" or 1 1/4" wide, 1/8" thick flatstock; I'm going to try to find simple (read: cheap) poly spacers, I'd rather not make them.
I had a moment this afternoon where a vision popped into my head. Would it be completely rediculous to mount this in front of my garden tractor? I think mounting it forward would offer a couple of benefits...
First, I think I could utilize the deck adjustment lever to raise/lower the flail blade assembly. (I have some 12 Volt solenoids, maybe rig a position sensor to idle the drive motor at full 'up')
Secondly, this would allow me to bag the raised thatch in the same pass.
Thoughts?
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
2017 KOMATSU  D61 PXI-24 (A52472)
2017 KOMATSU D61...
New Land Honor 9200 LB Ratchet Binder And Chains (A53002)
New Land Honor...
2015 INTERNATIONAL PROSTAR TANDEM AXLE MID ROOF SLEEPER (A52577)
2015 INTERNATIONAL...
CHANDLER 20FT 16 TON HYDRAULIC SPREADER (A52472)
CHANDLER 20FT 16...
