Anyone ever remove the bolt with the ball bearing and spring.
   / Anyone ever remove the bolt with the ball bearing and spring. #1
atsah
Elite Member
Maine/Florida
John Deere 3025E
On the left side of the frame in the suction screen area? I took it out by mistake and thought, ut oh, I put it back in the way it came out quickly.
   / Anyone ever remove the bolt with the ball bearing and spring. #2
Haven't taken that one out, but did remove a similar item on the transmission cover connected to the 4WD selector lever. I believe it's a center-position detent for one of the controls on the left fender there. If you didn't lose any fluid I doubt you harmed anything.
   / Anyone ever remove the bolt with the ball bearing and spring. #3
Ball bearing and spring? near the filter area?
Gee, that sounds like it might be a check valve to prevent oil from flowing back to the sump,
You might just be starting your engine on dry bearings in future.
Best to check the parts manual to determine function just in case.
I installed it the way it came out so I don't think any harm was done I was just wondering what it was, my guess is it is probably a check valve of some sort as irvingj posted. I used the tractor yesterday and everything works as it should. I engaged my rear pto just to make sure it worked okay.
   / Anyone ever remove the bolt with the ball bearing and spring. #5
No, not a check valve, just a spring-loaded ball detent so one of your levers will "click" into the neutral position, giving a tactile feel. At least that's what I believe it is.
   / Anyone ever remove the bolt with the ball bearing and spring. #6
detent ball is a pretty common thing, used in cars, tractors, trucks, and all kinds of equipment for probably over a hundred years. good thing to understand. probably get a billion hits if you google it.
That's what I meant to say, all my levers feel the same. I believe that is what it is as well.
   / Anyone ever remove the bolt with the ball bearing and spring. #8
Glad it has worked out OK.
Only reason I suggested check valve was due to the location.
Ball and spring is usually 'dedent' mechanism but can also be a check valve device.
Ya I put it right back in after I took it out, I don't know about anyone else but when I see a ball bearing and a spring pop out of behind a bolt, It kind of surprises me and I just want to reinstall it as quick as I can..
   / Anyone ever remove the bolt with the ball bearing and spring. #10
You got lucky, one guy on another thread though he was taking out a drain plug but it was actually a pin that held a shift fork and as soon as he took it out it changed positions on him and couldn't replace it, he ended up splitting the entire tractor to line it back up.
Generac Generator (A51691)
Generac Generator...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
Electric Mobility Scooter (A51694)
Electric Mobility...
14ft Bi-Parting Iron Gate (Cow Design) (A51573)
14ft Bi-Parting...
2004 JOHNSTON STREET SWEEPER (A52577)
2004 JOHNSTON...
