Anyone else get confused operating different things?
   / Anyone else get confused operating different things? #1
bdog
Elite Member
Texas
John Deere 6130M
Not permanently confused but temporarily. Over the past couple weeks I have been operating a HST backhoe, a wheel loader, a skid steer, my auto pickup, a Kenworth dump truck, a smaller dump truck with a syncronized transmission and probably something else I forgot and I find myself having brain lapses. Like the wheel loader just has an accelerator pedal and a brake and you shift forward to reverse with you hand on the loader control. I find myself trying to push down on the pedal with my heel like I do on the HST to go backwards. After driving the Kenworth and hopping in the small dump I try to float gears. Today on the way to lunch in my pickup I tried to push the clutch at a stop and momentarily freaked out when I couldn't find it.
   / Anyone else get confused operating different things? #2
No, it is just you.:D Just kidding.. I have done the above a couple of times in my Chevy truck, after operating the HST tractor for long periods of time... pretty disappointed too, when it did not go into reverse. To think you have to actually move that stupid shift lever... :)
   / Anyone else get confused operating different things? #3
After driving a stick shift car for 15 years and although I also drive an automatic truck, a few weeks ago driving our new Impala with an automatic I went to push the clutch in hard and almost put my wife through the windshield when I hit the brake with my clutch foot.
   / Anyone else get confused operating different things? #4
Back in the eighties, I ran a forklift as part of my job at a photo copier company. I would get in my car at the end of my day and pull the blinker back to back out of my parking spot.
Now, I have trouble between my JD tractor and Kubota Wheel Loader. I just changed the transmission in the JD including a left hand reverser, hoping to make things a little more "standard" but with the JD still having a clutch, not sure this will work out.
When test driving the JD with the left hand reverser, I had some tense moments with approaching traffic and did not quite know what to do, even though the clutch and brake were still there as usual.
   / Anyone else get confused operating different things? #5
I have two ford 350 one a auto and one a standard, and a for van, (don't drive it much), but the keys are in different places, the van is on the dash, left side of the steering wheel the auto is on the right sides of the steering wheel, and the standard is newer and on the column, drive one for a while and take a few seconds figuring where the key is in the truck, or between the two one tones try to shift the automatic, or forget to shift the standard, since the truck are the same color and make and the dashes all look the same, yes I have lapses,
   / Anyone else get confused operating different things? #6
At work we have a Montana that I hop on sometimes. It is an HST, which matches the Ford and Kubota at home. It has two pedals side by side for forward and reverse. I often plant my heel and am surprised it doesn't back up.
A strange one was a couple years ago when I was headed home in my truck. I was daydreaming about a Z28 I had back in the 70's. Approaching the right turn off a 55 MPH road, I flipped the right turn signal on and while reaching for the floor-mounted shifter with my right hand and clutch with my left foot. The truck has an auto trans and column mounted shifter.
   / Anyone else get confused operating different things? #7
Sounds like you drove that Camero down Memory Lane, and were turning onto Sentimental Boulevard. Was it a nice trip? *grin*
   / Anyone else get confused operating different things? #8
I do that ALL the time. My normal vehicles are both Jeeps with 5 speeds - one is a Wrangler, the other is a Cherokee. When I get into SWMBO's Durango, my left foot immediately hunts for the clutch. She usually doesn't notice that! But she always seems to notice when I'm feeling around in mid-air for the gear shift when starting to back out of the garage or when I'm trying to downshift when slowing down.
Happy to hear it's not just me!
   / Anyone else get confused operating different things? #9
Back in the day when we cut a lot of hay, I would get in the truck when finished for the day and try to turn it using the brakes. Actually, I bought a tractor severals ago for this issue especially. I was replacing a JD 1530 that was close to 40 years old with a lot of hours and a lot of rough usage. I was considering a new tractor either a JD or a Kubota. Luckily, I found a great J D 2155 that had been treated wonderfully. I chose it instead of a new one just because it was identical to my 1530 except in much better condition and 25 years newer.
   / Anyone else get confused operating different things? #10
My dad always thought I drove too fast, and he was right, but at the time I wasn't having any of it.
One early Spring day, with me driving and Pop riding shotgun, I spied a suspension eating pothole, coming at me, fast.
Dad saw it, too.
His left foot made an audible thump against the rubber floor mat "airbrake" as I calmly steered around the pothole.
I smiled. He said "Slow down". I did.
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
1265 (A50490)
1265 (A50490)
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
