Texan4Life
I'm just curious as I bent one two days ago. I really wish I would have taken a picture of it bent but I didn't think of it until I straighted it back out.
What was I doing you wonder?
Well I was using the rear blade on the box blade to push a tiny little 3 inch stump out of the ground. I figured it was no match for the tractor so when I was about 6 inches to a foot off center of the blade I figured no biggie. Well I backed up nice and slow, the tires dug in, and then I had the bright idea to lift up a little on the hitch as it had a good bite on the stump. And then it turn the arm into a pretzel. Of course I felt like a moron the second this happened and that I should have known better. I Guess I'm to used to our IH Hydro 70.
Good thing was it only bent the straight part of the arm so I put it in our shop press and flattened it back out. But during the flattening it cracked
So now I get our harbor freight arc welder and put my 5 hours of self taught welding skills to use. And considering, it turned out pretty good. The crack was just half of the arm from the hole to the top of the arm
