Anyone added 3-pt TILT to a JD 4100?
   / Anyone added 3-pt TILT to a JD 4100? #1
jimgerken
Veteran Member
Minnesota
John Deere 3720
I am interested to know if anyone has added tilt to the JD4100, 4110, 4115. I have the top cylinder, but now feel I could benefit from having TILT. To be clear, I understand that TILT means replacing the adjusting lift arm mechanism with a hyd cylinder, so you can tilt an attachment. This would allow , for example, using a blade to contour a trail into a hillside. The area on the 4100 is small, and short (maybe 16" long). I would assume I would want at least a 2.5" diameter cylinder for the loads it will see. Any input (pics if possible)? Thanks. /forums/images/graemlins/grin.gif
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2020 JLG 1732 16,755lb 4x4 High-Capacity Rough Terrain Telehandler (A49461)
2020 JLG 1732...
2007 MACK CHN613 (A50854)
2007 MACK CHN613...
71053 (A49346)
71053 (A49346)
Polecat swift 206R (A50322)
Polecat swift 206R...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
