Anybody use Napa hydraulic oils in Mahindra?
   / Anybody use Napa hydraulic oils in Mahindra? #1
jrchafin
Mahinda 7520
I'm tired of trying to find the very limited hydraulic oils that Mahindra specs for 7520. The engine oil is easy enough to find, but the list of compatible hydraulic oils are not available in my area. Specifically:
1. Chevron 1000 THF
2. Texaco TDH Oil Special
Is there really a difference between this and Napa's? Or tractor supply, advance auto, etc.?
   / Anybody use Napa hydraulic oils in Mahindra? #2
I can only speak to my BX. I went with universal hyd. fluid from Advance auto one time. After 2hrs run time I notice the tractor was not feeling the same. I checked the fluid level and no problem. Later I smelled hot oil. Sure enough the universal oil was heating up.
I drained it and had the distinct smell of burned oil. Went to Kubota and got the SUDT2 oil and all was well again.
I stay with what the manufacturer recommends.
   / Anybody use Napa hydraulic oils in Mahindra? #3
Can you find Mobil 424? Thats about the best here.
   / Anybody use Napa hydraulic oils in Mahindra? #4
1. Chevron 1000 THF
I suspect only small difference between the conventional oils. I use KUBs SUDT to go a step better.
larry
   / Anybody use Napa hydraulic oils in Mahindra? #5
1. Chevron 1000 THF
For my 2008 Mahindra 5525 my dealer recommended any decent quality fluid that meets the John Deere 303 spec. So I use Tractor Supply Traveller universal tractor hydraulic fluid. The 303 spec is an old spec but many hydraulic fluid manufacturers still test their THF to ensure that this spec is met. It's a legacy thing, I suppose.
Don't know if your 7520 is different for some reason.
   / Anybody use Napa hydraulic oils in Mahindra? #6
If SCHAEFFER'S is available in your area go with #315 SIMPLEX SUPREME and be good for LIFE, If not go with the cheap stuff such as TSC TRAVELLER .
   / Anybody use Napa hydraulic oils in Mahindra? #8
I use NAPA 85-405 in my BX and have had no problems, the so called whine factor others talk about if not using KUBOTA SUDT-2 did not occur in my case. 1500 hours should be a decent test.
Ron
   / Anybody use Napa hydraulic oils in Mahindra? #9
Flusher, yes the 303 spec was fine for the simple transmission and hydraulics on the 5525 and it was the norm for years, but for most models we now suggest they should meet JD20C specs. The JD20C spec is pretty current and not so hard to find. Or use Mahindra fluid if you are near a dealer.
   / Anybody use Napa hydraulic oils in Mahindra? #10
Traveller® Universal Tractor Trans/Hydraulic Fluid, 5 gal. - Tractor Supply Co.
this is the stuff to get. Not the stuff in the yellow container. This actually mentions Mahindra on the container.
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A52748)
FIRESTONE 9.5L-15...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A52748)
2015 Ottawa Yard...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A52748)
UNVERFERTH 330 -...
