Industrial Toys
Super Star Member
- Joined
- Feb 25, 2008
- Messages
- 16,742
- Location
- Ontario Canada
- Tractor
- Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, 4x4, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule, JD 4x2 Electric Gator
I have a princess Auto Digital Style Load Tester. A friend of mine who deals in a lot of batteries keeps giving me used batteries that are "supposed" to be good. A got about eight different ones lately, and after charging them to around 13 volts for days on a small Schumaker charger ,my tester shows all of them FAIL, even at very low CCA settings.
Is my tester lying to me? All batteries pretty much read ten point something volts almost immediately when the device applies load, then shows fail.
So I did several things. Firstly let me say that the device does not change load resistance, only changes the time the load is applied to the battery based on CCA ratings. Is this a poor way of measuring different size batteries?
I checked the voltage measured my the tester with a fluke meter and believe the tester is accurate.
I measured, the current going through the tester with a Fluke clamp on DC meter and got a reading of 100 amps at the ten point something volts.
So my question is. If one puts a load of 100 amps on a good battery, is it normal for the voltage to drop to ten point something volts or is that too low?
