Anybody got an engine pulley
/ Anybody got an engine pulley #1
jerrywayne
radisson wi
mtd riding landowner 2004
Im looking for an engine pulley for a 2004 mad lawn mower. does anybody know of a place for one beside mad inc themselves?
/ Anybody got an engine pulley #2
Hello Jerry,
Could you provide a little more information? I've never heard of "mad" brand, and searching didn't turn up anything relating to a lawn mower other than some people who were mad about some brand of mower.
To find a generic pulley, you need to know the bore size (diameter of the hole in the pulley which should be essentially the same as the diameter of the shaft the pulley is on), the diameter of the pulley (complicated; see * below), and width of the belt (or belt number). The pulley is probably keyed to the shaft, but that should be a standard size key. If it isn't keyed to the shaft, then we'll need more information about that.
*The pulley diameter is not the outside diameter of the pulley. It depends on where the belt rides in the "V" of the pulley, and more specifically, where the fibers that give the belt its strength ride on the pulley. That's usually a little under the outer surface of the belt and roughly 1/4" less than the outer pulley radius, so roughly 1/2" less than the outer pulley diameter.
You may also find this part under the name "sheave" rather than "pulley".
Do you have a part number from this "mad" company?
Give us more information and we might be able to help you find this part.
Mtd i have a picture of the original pulley that i can download
/ Anybody got an engine pulley #4
Jerry,
MTD.... Was "mad" a typo? I wondered if you meant MTD since that's what you have in your profile, but you used "mad" twice.
Nevertheless, MTD has made many, many lawnmowers. Do you have a model number? Any kind of identification numbers from the mower? MTD also makes mowers sold under other names. The more information you can provide, the more likely you'll get a helpful answer!
13am660g752 mtd yard machine
/ Anybody got an engine pulley #7
Welcome Jerry to TractorByNet. How about posting a picture of your Mad Machine. -kid
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
2016 KENWORTH T270 SERVICE TRUCK (A62130)
2016 KENWORTH T270...
John Deere Z997R (A60462)
John Deere Z997R...
Genie GTH 844 Telescopic Forklift (A62180)
Genie GTH 844...
APPROX (14) 20'-35' HEAVY DUTY INSULATED PANELS (A62131)
APPROX (14)...
2008 Lexus IS250 Sedan (A61569)
2008 Lexus IS250...
