Anybody ever build a tonneau cover?
   / Anybody ever build a tonneau cover? #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
I'm thinking about building a tonneau cover out of plywood hinged, in the middle. Does anyone know how to keep it from leaking at the hinge and atound the rim of the pickup bed.
   / Anybody ever build a tonneau cover? #2
Personally, I would use a closed cell sponge tape stuck to the tonneau cover around the bed sides. A rubber strip from an old bicycle inner tube sandwiched between the cover and a piano style hinge would seal that area.
That how I would do it.
Others will come up with other ideas
   / Anybody ever build a tonneau cover? #3
You can have mine around noon time most days. Bring pizza and a helper to load it.
   / Anybody ever build a tonneau cover? #4
Yep, like Chopperhed said, a good rubber strip on top of the hinge "tacked on".
Make sure the rubber is pliable when cold.
   / Anybody ever build a tonneau cover? #5
I made a tonneau cover 20+ years ago out of 1/2 plywood, 2x2's, carpet padding and black vinyl. Mine was rigid and not hinged. The edge of the vinyl was stapled to the underside of the plywood where it would be hidden. Water managed to seep under the edges and soak the padding and plywood over time. I have no idea how you'd get a good waterproof seal over a full length hinge.
Thanks to everyone for your replies. The few diy tonneau covers I've found on line didn't address the issue. I'm guessing they leak badly.
   / Anybody ever build a tonneau cover? #7
Take a look at
hatches that are on boats. Fiberglass bass boats, runabouts, cruisers, ect. They all have a lip or channel on the bulkworks or the other door if its a double door. Hope that helps.
Hiltz,
That does help. Thanks!
   / Anybody ever build a tonneau cover? #9
Don't bother making one when a killer double opening diamond plate unit is available from Diamondback.com! I've installed two (2) units on my GMC 2500HD/Duramax trucks which I use to haul my camera gear around. Wouldn't use anything else. Period. Check them out.
   / Anybody ever build a tonneau cover? #10
I had one on an old Datsun pickup. It had 3/4" ply with a offset printing blanket over the top. It was hinged in the middle and could be locked to the tailgate. It was strong enough to take a good load on the top.
CABINET (A53843)
CABINET (A53843)
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
UNUSED HURRICANE 20' X 20' ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
2016 INTERNATIONAL LF687 (A53843)
2016 INTERNATIONAL...
2018 Ford F-150 Ext. Cab Pickup Truck (A51692)
2018 Ford F-150...
