Anybody done a "Heater Bypass Mod" for better A/c on Ford PSD?
   / Anybody done a "Heater Bypass Mod" for better A/c on Ford PSD? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
I just ran across a thread on a Ford Forum about turning off the radiator hose that goes thru the heater core and getting 10 degrees more cooling in the cab of your truck.
The reason for doing this mod is to shut off the flow to the heater core while the A/C is running thus allowing for cooler A/C .
yet another mod done~PIC~ heater core bypass valve - Ford Truck Enthusiasts Forums
Apparently it can be as simple as installing one ball valve or can be easily gone further with a Ford Ranger valve and hooking into the vacuum system.
Has anyone here done that? How difficult was it compared to say changing a shock absorber?
Any down sides?
   / Anybody done a "Heater Bypass Mod" for better A/c on Ford PSD? #2
Haven't done it, but it the ball valve version should be as easy as cutting the hose in half, sliding the barbs on the valve into both sides of the cut and tightening two hose clamps. You might see if a PEX shutoff valve is the right size. That will have the barbs already on it.
Aaron Z
   / Anybody done a "Heater Bypass Mod" for better A/c on Ford PSD? #3
I did it in my old '92 F250 IDI with the vacuum operated valve, never noticed a difference honestly. I put this in category of what I call "mental mods" meaning you want to believe it makes a difference because you spent time and money doing it.
   / Anybody done a "Heater Bypass Mod" for better A/c on Ford PSD? #4
A lot of older trucks had a shutoff valve. (Usually mounted on the water pump outlet) None of these came with A/C of course.
   / Anybody done a "Heater Bypass Mod" for better A/c on Ford PSD? #5
Only works if the factory heater valve was not 100% closing. Around here we need heated defroster operation morning and evenings to keep the windshield from fogging . Even in June, July and August .
   / Anybody done a "Heater Bypass Mod" for better A/c on Ford PSD? #6
Where is that???
Simpson 3100 PSI Gas Pressure Washer (A51573)
Simpson 3100 PSI...
2010 Chevrolet Tahoe SUV (A52377)
2010 Chevrolet...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
2019 FREIGHTLINER CASCADIA DOUBLE BUNK SLEEPER (A52576)
2019 FREIGHTLINER...
FRONTIER MG20F LOT NUMBER 82 (A53084)
FRONTIER MG20F LOT...
2012 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2012 MAC MFG 53'...
